anyone ever have this prob with their T25 EsCos ??
Old 01-02-2007, 06:30 PM
ThomasV
ThomasV's Avatar
Default anyone ever have this prob with their T25 EsCos ??
AaaAAaaarhg!!
Have a fooking annoying problem with my small turbo EsCos.
It hesitates and chugs when giving it full throttle.... It drives fine and works perfectly when only giving it ½ or even a little more throttle... but at full throttle, the problem occurs. !
I have cleaned the MAF, changed the plugs, changed the fuel-filter.... didn't help.
Anyone got an idea ? ....
Will put an error-reader on it next week but would like som good advice if anyone has any....... HEEEELP ...
/Thomas
Escort Cosworth '94 T25
Radiant Red
Old 01-02-2007, 07:10 PM
redrsmk5
redrsmk5's Avatar
Could be coil packs on the way out or the new plug gaps?
Old 01-02-2007, 07:30 PM
ThomasV
ThomasV's Avatar
What are the correct gap on the plugs ? .... they are new standard motorcraft from FORD...
/Thomas
Old 01-02-2007, 07:43 PM
MarkN
MarkN's Avatar
These cars are dead sensitive to plug gaps. Mine kept hesitating until I closed the gaps to the correst size. It's pretty small - I'll find the handbook and look it up
Old 01-02-2007, 09:02 PM
ThomasV
ThomasV's Avatar
Cheers MARK ..... appreciate it mate!...
/Thomas
EsCos T25
Old 02-02-2007, 12:36 AM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
defo sounds like gaps to me mine used to do that!!! i shrunk my gaps and solved it
Old 02-02-2007, 06:31 AM
bpspa
bpspa's Avatar
I had the same problem turned out to be one of the coil packs, but I would check the plugs first as they are cheap compared to the coil packs
Old 02-02-2007, 08:36 AM
ThomasV
ThomasV's Avatar
Will def check out the plugs but I can't imagine that standard plugs bought from FORD will get my car running SO bad ! ....
Coil pack would be more probable ..... but will try error-code reader and plugs first..... cheaper.
Is it correct that the electrode gap should be 0,8mm ?...
/Thomas
Escort Cosworth T25
Old 02-02-2007, 04:57 PM
redrsmk5
redrsmk5's Avatar
Sounds silly but also check that the multiplugs on the inner wing are together properly, if these come a bit loose they affect a lot of stuff!
Old 02-02-2007, 08:54 PM
bpspa
bpspa's Avatar
I think the gap should be around 0.7 mate.
Hope you get it sorted
Old 02-02-2007, 09:34 PM
adamski frst
is this helps i have my old coils and brand new MAF sensor old map sensor etc for sale...now i had my conversion
Old 03-02-2007, 08:42 AM
ThomasV
ThomasV's Avatar
is it a standard T25 map-sensor ? .... if yes then im def. interested!....
How much for the coils ? ....
/Thomas
Escort Cosworth '94
Old 06-02-2007, 04:09 PM
ThomasV
ThomasV's Avatar
Default SOLVED
Problem solved!! (I guess)
Error code reader said CODE 22 which is MAP-Sensor fault... so, If anyone else should experience what I have, then you know where to start looking.
/Thomas
Escort Cosworth '94
Radiant Red
Old 06-02-2007, 05:40 PM
sailorbob
sailorbob's Avatar
There's something wrong that code, the small turbo Escort's error codes are 3 digit, the only 2 digit codes you should get are code separators and instructions to do things like goose the throttle during KOER tests.
Old 06-02-2007, 06:06 PM
ThomasV
ThomasV's Avatar
well, I'm pretty sure that it showed 22 however I could be wrong....(was standing a few meters away)
The chap that did the testing works for FORD and is known as a electronic wizard around Cossie owners, so .... I trust that what he said is correct.
Ofcourse, I will know when I swap the sensor...
/Thomas
Old 06-02-2007, 06:36 PM
sailorbob
sailorbob's Avatar
MAP sensor related errors for the eec-iv Cosworth are;
126 - MAP sensor out of range
128 - MAP vacuum has not been changing
129 - no MAP or MAF sensor change during goose test
Error 22 is 'MAP vacuum or BARO signal out of range' on most 2 digit eec-iv ecu's but the Cosworth can only output 3 digit errors. Maybe the guy's got some oddball kit that cannot display 3 digits but can read them!
Old 06-02-2007, 08:49 PM
MarkN
MarkN's Avatar
Beware of erroneous MAP sensor faults on T25 Cossies. Mine spits them out occasionally - normally the one about MAP sensor input voltage above spec. It's a bit of a red herring to be honest because the MAP has nothing wrong with it.
There was a TSB on small turbo cossies to do with rerouting the MAP sensor to ECU wiring because it was subject to interference from the rest of the loom. Mine hasn't has this work done and I don't fancy doing it. PLus the replacement loom part is probably NLA.
I've put the peculiar MAP sensor readings down to this rather than anything else. But as has already been said 22 is not a valid code for this version of EEC-IV. Are you sure that he isn't misinterpretting the all clear signal which is two "ones" twice?
Old 07-02-2007, 08:38 AM
ThomasV
ThomasV's Avatar
The reader was only 2-digit .... and it did say 22.
He then looked it up in some sort of manual and the book said it was a MAP sensor error.
That's all I know .... have just bought a used, but working, MAP sensor so will now soon enough if the reader is right..... or not.
/Thomas
Escort Cosworth '94
Radiant Red
Old 14-02-2007, 01:28 PM
ThomasV
ThomasV's Avatar
Default PROBLEM SORTED
Hey all,
well..... it turns out that the problem was NOT the map-sensor (even though it gave an error when put into reader).
The problem was electrode gap on the spark plugs.
These were WAY off from factory so adjusted to 0,7mm and now the car works perfectly....
So... if anyone else should have these problems, well .... now you know where to check.
/Thomas
Escort Cosworth '94
Radiant Red
gcfcos
59
06-10-2015 05:04 PM
gcfcos
88
15-09-2015 03:48 PM
gcfcos
11-09-2015 06:03 PM
Mickeystewart
09-09-2015 04:04 PM
Quick Reply: anyone ever have this prob with their T25 EsCos ??
