500 Coolers
500 Coolers
Whats the main differences between a 2wd 4wd and escos 500 style coolers as i have one off my old 2wd and was wondering how much work it would be to make it fit.
Mounting brackets and the direction the pipes come out the cooler Should be easy enough to get it welded the direction you need it too, i'd certainly look into it.
My old EsCoss had a Saff 500 cooler made to fit
use 2wd silicone pipes-
the escos 500 cooler has its pipes in a different position to the 2wd as the escos silicone pipe is shorter and at a different angle due to the charge cooler that is fitted as std
