whos running antilag
who running antilag on there escort
and has anyone had probs ie when we flick the switch to turno on the car revs very very high is this normal if we blip the thottle then it go even higher ???? why is this it runs fine when switched off??? can anyone help as were stuck and cant figure this out??? thanks all ian |
forgot to mention we have taken the dump valve off as we thought it may be leaking ??plus can you run als with a dump valve as we dont want to run a dump valve as we want the flutter or chatter?
we havnt ried it yet with out but has anyone had any probs that we should know before hand?? :cry: :cry: :cry: :cry: |
i run anti lag on mine m8, no probs wot so ever just flick the switch rev her up 2 about 4000rpm and she's away.....av u had ur throttle body modified....?
YES HAVE HAD IT MODDED
you will lose the idle vale for idle control witch can upset idle when cold, but well worth it !!! |
© 2024 MH Sub I, LLC dba Internet Brands
