transfer box oil
what oil should be used???whats the best make to get??cheers people :top:
Auto transmission fluid for the trasfer box and gear oil for the gearbox, 2 different oils in the gearbox. ;)
"2 different oils in the gearbox"
what do you mean by that mate,i have some mt75 oil from ford for the box-is there a mix which is better??? :clap: |
forget that mate isee what you mean-transfer box=atf and mt75 gearbox oil in the gearbox itself,thanks again
as above - tranfsfer box uses 0.5 litre of ATF fluid ( DEXRON 3 ) and the gearbox uses a specific oil for the MT75 box, and needs 1.3 litres
I'm using Mobil 1 75W90 full synthetic in both gearbox, transfer box and diffs :top:
Standard transfer case, DPE gearbox with straigh cut 2nd and 3rd gears and a Quaife ATB front diff. The oil was recommended by Pete Dougherty and Ahmed Bayjoo :top:
Paul,
how do you find the gear change with heavier oil in than std? i thought the MT75 oil contianed a metal element that helped the bearing life or something..? is it any quieter when its hot - as the std boxes rattle like a bag of bolts when the oil is hot dont they, does it affect the viscosity of the centre diff using a heavier oil than ATF..? |
Not driven it yet lol
Will let you know :top: |
:top:
no :(
Merke FORD
Modell Escort RS Cosworth (4x4) Motor BT År 1992-96 Bruksområde Anbefaling Kapasitet (l) Motor (BT) Best EDGE SPORT 0W-40 (m) 3.6 Bedre GTX MAGNATEC 5W-40 (m) Bra GTX 5 LIGHTEC 10W-40 (m) Manuell girkasse Best SMX-S 1.2 / 2.4 Bedre FMT Automattransmisjon Differensial Best SAF-XO 75W-90 (b) Bedre SYNTRAX UNIVERSAL Kjølemiddel (50%) se handbok / katso käsikirjasta 7.5 Overføringskasse Best TQ DEXRON III 0.3 / 0.5 Bedre TQD Servostyring Best TQ DEXRON III Bedre TQD Bremsevæske RESPONSE SUPER DOT 4 Differensial foran Best SAF-XO 75W-90 1.3 Bedre SYNTRAX UNIVERSAL |
© 2024 MH Sub I, LLC dba Internet Brands
