specs of your 450++hp cossie please
hi can you guys and girls give me the details of the specs of your engines?compression,pistons,turbo etc and what you recon the engine owes you?just trying to get a rough guide and the best spec for the money.
Why not give one of the many tuners a ring, if your seriously after a big spec engine then they can give you what your after and a price
Plus 50bhp less than your previous post isnt really going to make much difference...............................is it
Caraholic
450bhp is going to be £10k + VAT OUTRIGHT (dynoed, but not installed). Using your block, rods, crank etc, will reduce the price, but your engine needs to be stripped and assessed to see what CAN be used.... Could go as low as £7.5 - 8k + VAT installed, depending on spec and what is required over and above your own engine.
He was simply referring back to this post
https://passionford.com/forum/viewtopic.php?t=230829
as said 8k to 10K for engine
other engine bits like upratted rad, intercooler, tanks,ect £1k
front diff and rear diff ? about 3k
clutch and gear box start from about 3k
brakes and shocks from 2k
so to do it right about 20 k for a standard car as a base
ive got ap brakes,avo coilovers,polybushed,uprated diffs but a standard box,and the rest of the stage3 basically.ive only had the engine a few months but am kind of bored already.itd mainly be a fast road car but im wanting to use it on track more regular next year.its only a toy not a daily runner.
can be built a lot cheaper if your williing to do it yourself,
i have replaced head gasket and cams eals in my own car,
all done by myself and friends (mostly daz c)
now, i have simpply save d myself best part of probably 400 quid by doing that,
if i was to want more power now, i would simplly strip the engine myself
get the bottom end proff rebuilt annd thats it, a few of my mates are all DIY enginie builders, so now probs there,
which inc the fastest RWD cossie in UK (road legal)
What you mean is the fastest 1/4 mile RWD 3 door.
