escort block
escort block
hi lads have decided to tackle the head gasket on my 93 escort cossie .started to dismantle and heres wat i found.firstly when i removed the inlet i noticed my block has 200 stamped onit .wat block should i have .secondly when i removed the rocker cover i noticed the bearing cap on the gearbox end of the inlet cam was loose only to discover one bolt was loose and the other had rung off in the head and the cap had been siliconed in place by the previous owner,wat a boge.what i need to know is can these b helicoiled and has anyone done this or would i b better off sourcing another head
sorry wat i meant is did the escort cossie originally come with the 200 block and the 2wd engine was a 205 block .the head does look pretty descent and clean but i tink il send the head off for a rebuild and have new cams and bearing caps fitted to b safe ,wont know till i remove the head and examine it a bit further
tanx for the help guys ,just have to get the head off now and cleaned down and inspect the cam bearing lobes to see if it did any damage with the bearing cap being loose
