centre console
how do you remove the centre console , ive got a new gearshift gaiter to put on , but it looks like you have to remove console to replace it, do i need to remove the screw under the ashtray?
2 screws under the head unit, 1 plastic clip either side at the back and 1 or 2 screws under the electric window switches, be careful when taking the electric window switch panel out. I found it easier the pull the actual switches out of the panel first, then you can see how it comes off..
hth :DD: |
© 2024 MH Sub I, LLC dba Internet Brands
