adjustable tca's or adj top mounts
Out of interest, which would be better upgrade for the standard road car with coilovers and 18" alloys? Or is it even possible to use adjustable top mounts with Gaz coilovers? Is there any drawbacks using adjustble top mounts in road car?
Just seen these on ebay... http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=8046409457
Hmm, It didn't come in to my mind that those top mounts wouldn't fit standard car So that's the point most of the people are using adj tca's because they are alot easier to install. But if I could do top mount swap, would it be better option than the tca? One thing that comes in to my mind is that it would make the top mount solid and I guess that it would be better option than the standard one.
Originally Posted by Azrael
What kind of mods are required to fit those adjustable mounts on Escos?
Auuuuu so it ai't easy - pretty big thing to do :-(
Camber plates on Impreza or Evo are such an easy fit :-(
I have both fitted to a car and they are straight bolt on. Top mounts need some extra holes drilling.
It is the setting up that is real important. You need a patient good geometry guy who is willing to set the suspension up on a 4 wheel alignment system
No I didn't take any pics. It use to be part of my job a few years back.
How I did mine was to fit top mounts first and set basic Camber, Castor and track. Then fit adjustable TCAs and compression struts and then fine tune the settings to what suits the cars use ie Rallying or track use.
If you have coil overs your ride hieght will need to be set up first and any corner weighting done.
The geometry system I use to use was a camera system fitted to all 4 wheels on a ramp with turn tables. That way adjustments could be made without the need to keep jacking the car up. Both front and back can be done depending on whats adjustable. (I found it easier on some vehicles to have the bumpers removed)
If you try and do it in your garage or at home you could make the car virtually undrivable
ozcos It didn't get myself understood. Sorry. I ment the top mounts how they actually work. You can just rotate them to get the right setting? That must force big compromise?
Sorry mate, no not to bad, they are offset as you say,so you just rotate them close to your desired settings as possible, you may not get it spot on but thats when you can finalise it with the bottom adjustments.
There are also many other considerations on the alignment that I haven't mentioned such as set back and toeout on turns... Thats why its best to fit parts with access to the alignment equipment
It does however make for a hard ride as there will be no rubber/ polly bushing left...... But on smooth road/track
AZRAEL...
As your roads are bad I Would suggest no more than polly bushes for your suspension as you do not want to take the pleasure away from driving a great car.
And there is nothing worse than driving a car with to hard a suspension on rough roads
Good luck mate
Mark
Good luck mate
Mark
ozcos I know I know. It's very much like driving a rallycar now anyway. I justhave to fine tune some geometry parameters and was wondering but it's probably not the best idea. Bodyshop welcome too
JK12
33
26-04-2021 12:09 PM
