pedal box into mk2
pedal box into mk2
hi just wondering how hard it is to fit a 3 pedal pedal box into a mk2? does it involve cutting and welding the car? want to fit one as much neater in the engine bay
cheers jim
cheers jim
I think he means a 3 cylinder bias pedal box (clutch, front & rear), if that is the question, the answer is, you don't need to modify anything on a MK2 to fit a bias pedal box, the only negative about having this configuration is access to the cylinder when they are in situ, it is tight if you have to remove or do any maintenance on the cylinders....
Also take care with the selection of feed pipe you use, buy it from somewhere like Squires or West Wales or even better Gartrac...I've changed a when people have scrimped on rubbish pipe....
HTH
Ian
HTH
Ian
Steve Escos
01-10-2015 06:57 AM
Russ Payne
25-09-2015 08:29 PM
