Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Capri Sierra Rear Axle Conversion...
Old 03-02-2010, 07:01 PM
G_T_M
G_T_M's Avatar
Default Capri Sierra Rear Axle Conversion...
I've heard of it being done, does anyone know anything about it?
When I think about it, a 2WD cosworth rear axle could work out cheaper than all the parts for atlas/leaf setup, as well as the bonus of independant rear suspesion, rear disks, lsd and bang on the rite ratios.
Some pictures would be ace for some insperation
Thanks for your help
Old 04-02-2010, 06:08 PM
G_T_M
G_T_M's Avatar
I'm the only one on that one then..?
Old 05-02-2010, 07:05 PM
graham c
graham c's Avatar
i thought about doing it when i built my first one should be good i think
Old 05-02-2010, 07:28 PM
If going to the trouble of this magnitude, there are far better set up's than a cossie rear, and most likely cheaper too, sierra rear suspension is nothing to shout about!!
Old 05-02-2010, 07:48 PM
graham c
graham c's Avatar
the s14 ? nissan 200 sx? or is it s12 ? jap crap
Old 05-02-2010, 10:02 PM
caprizetec170
caprizetec170's Avatar
I was thinking of similar rear end set up but probably only sierra parts il use are the diff drives and hub carriers and fab trailing arms to hang off front spring mount and diff craddle
Old 05-02-2010, 10:31 PM
m4tt274
m4tt274's Avatar
the p100 has the leaf atlas setup and i converted to cossy rear, not that hard, cheap and far better. would recomend it. there are better setups but keep it ford, and simple.
Old 16-04-2011, 02:14 AM
russwdavies
russwdavies's Avatar
Default Sierra Rear End
I am going to try it. There was a car in Classic Ford mag with it done and I saw it at Ford Fair one year. It look OK and not a bodge job. If you take your time I think it shouldn't be too hard.
Russ
Old 18-04-2011, 09:37 PM
bangerboy33
bangerboy33's Avatar
Why lose the fun of a capper live rear axle! Where is the fun of having it grip round a corner instead of drifting round it lol
Old 02-08-2011, 03:52 AM
Bikerjohn
Bikerjohn's Avatar
I'm sure there used to be a Firm called Quickbits in the 1980's that did conversion Kits to put Mk2 Escort Running gear into sierra shells. they used Atlas rear axles on Sierra's.
I seem to remember "Fast Car" did an Article on the conversion....
Old 04-08-2011, 05:57 PM
Podgy dog
Podgy dog's Avatar
What mk Capri is it?
Old 17-02-2012, 11:24 PM
Ford nut 1988
Ford nut 1988's Avatar
Thumbs up capri cosworth axle conversion
https://passionford.com/forum/album....ictureid=23313
Hi there, thought id post a few pics of my 2WD cosworth rear axle conversion on my mk3 capri. the conversion took a few months to do and involved a lot of measurig (and head scraching) before cutting in to the chassis legs and building a base for mounting the beam, next we cut out the boot floor and braced the chassis with one piece of steel box tubing at the back and another one where the base for the diff to be bolted to. The next thing that needed doing was new strut tops which we fabricated ourselves, and weld up the old ones.
HOWEVER, im using 18 inch wheels with 245/40/18 tyres with a slight camber and fitting some extended wheel arches, the sierra axle is also wider than the capri atlas axle, so depeding on the wheels you plan on using this conversion might not be for you. But it is well worth it as its saved me £1400 on uprating the atlas axle and due to fitting coilovers its fully adjustable and capable of handling 400 BHP.
Old 03-04-2013, 10:31 AM
dr_ragnar
dr_ragnar's Avatar
Also done this (after copy the solution fro Realpinto),
It's a lot of work, similar to Ford nut 1988 here.
// Magnus, Sweden
http://www.capripower.co.uk/forum/in...capri-tribute/
Old 06-10-2013, 10:53 PM
BON_300
BON_300's Avatar
Hi
Anyone seen a Sierra fitted with a Live rear axle ?
Old 07-10-2013, 06:13 PM
Yeh there was a magenta saff in the ford mags years ago.Im sure it was a ford mustang.
Old 07-10-2013, 06:28 PM
BON_300
BON_300's Avatar
that's what I mean .....maybe somebody has some pics ...should be a cool project
Vacuman
16
03-09-2015 06:26 AM
robbo9006
11
01-09-2015 02:10 PM
andyrs1600i
30-08-2015 07:21 PM
Vincereese
15-08-2015 06:24 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Capri Sierra Rear Axle Conversion...
