Cossie misfire
Hi everyone.
Ive finally bought a sapphire cossie after wanting one since I was a kid but its started to misfire when its sat at idle. Ive put new spark plugs in, checked the phase sensor and gaps but it all seems to be ok. I was told to clean the idle speed control valve which Ive done but thats made no change either. Can any one help?
Thanks Damien.
Thanks Damien.
If by misfire yuo mean just missing a beat occasionly at idle, then check the CO% first...they can be quite fussy. If its near standard up to stage 1, set it for around 2%...if tuned higher then tweek it up a little to nearer 3%.
Any garage that aint run by monkey's can do that for you...shouldnt cost a sight as its only a 5min job.
But really, your best bet regarding fueling set up will be a rolling road session...well worth the out lay as you'll proberbly redeem the cost in saved fuel in the long run
Stu
Stu
While the engine is running try disconnecting one injector plug at a time. If the engine tone/rpm changes then that Cyl is functioning, if the tone/rpm dont change then that Cyl isnt functioning properly. At least by doing this test you can possibly narrow it down to a particular Cyl.
If you do find out that it is a single Cyl, then it could be a number of things, faulty plug lead, faulty injector etc etc.
If there is no difference in the engine tone/rpm by doing this test, then it is likely what cossie604 suggested.
had a similar prob, may need ya base idle re-setting..as the idle control valve only works when the engine is cold and when volts drop like when your driving with everything switched on.(ie lights/heater)wot did you use to clean the iscv ?
Russ Payne
Sep 25, 2015 08:29 PM
