cosworth cams problem
Old Feb 2, 2006 | 03:51 PM
duthie8969.fsnet.co.uk's Avatar
Default cosworth cams problem
can anyone help.i bought bd10 camshafts for my sierra 2wd cossie and can not get the timming to line up.if the block is on top dead centre the cams are out by just over one tooth on each cam what do u think
Old Feb 2, 2006 | 04:35 PM
Alvyn's Avatar
Alvyn
have you put them in the right way round?
Old Feb 2, 2006 | 05:27 PM
JesseT's Avatar
JesseT
I hope you have aligned it with the tooth and not the notch?
Old Feb 2, 2006 | 07:25 PM
Dave Henshall's Avatar
Dave Henshall
you have to manually holt the camshafts on TDC as they want to naturally rock over either a tooth forward or bckwards...
Old Feb 2, 2006 | 08:49 PM
yes it is timed up properly. when the crank is on the notch and try to time up the cams they come round so far and then the valves seem to hit the top of the pistons. someone told me that if the head has been skimed to mutch this could b the problem. could this be possible
Old Feb 3, 2006 | 08:38 AM
Dave Henshall
also wild cams like those will need pockets machining into teh pistons to allow the valves to be open for longer.
Old Feb 3, 2006 | 08:41 AM
Alvyn's Avatar
Alvyn
Originally Posted by Dave Henshall
also wild cams like those will need pockets machining into the pistons to allow the valves to be open for longer.
NOT needed when using bd10's m8
Old Feb 3, 2006 | 08:44 AM
Alvyn's Avatar
Alvyn
what are you calling the notch? the groove ??? if so then that's the problem as you use the lug nearset the groove to time up on the yb's engine
Old Feb 3, 2006 | 09:51 AM
Dave Henshall
like this...
Old Feb 3, 2006 | 03:21 PM
yes that is the notch i use to time it up.
Old Feb 4, 2006 | 09:31 AM
ajjames's Avatar
ajjames
as said before i would double check you have the exhaust and inlet cams in the right way around
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Aug 14, 2015 07:29 AM
