Cooling fan rotation Q?
If you reverse the polarity on an electric rad coolant fan, would it be as efficient if it were made to blow rather then suck? (ie mount it in frt of the rad rather then the rear)
Anyone tried it?
Anyone tried it?
Just lookin at this http://cgi.ebay.co.uk/1-X-13-SPAL-12...QQcmdZViewItem
Is that right or misleading then? I see that has straight blades so I assume it could run either way?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
