help required
Old Dec 9, 2005 | 01:31 PM
fordsportjay's Avatar
fordsportjay
Default help required
hi everyone
still got this problem with the escort cosworth flooding the cylinders.originally i changed the blue temp sensor and the phase sensor.it attempts to fire but then floods and when you remove the plugs they are soaking wet and you can see a pool of fuel in the cylinders.
as the car was in bits the owner decided he wanted to upgrade to stage 3 so went to collins to get the bits.we were talked into going light blue injectors with the standard 2.5 bar map sensor with a new chip-sue says this works great on escort cossies with about 20psi boost.
fitted all the new bits,changed the blue temp sensor back to the old one and replaced the phase sensor and regapped it.still the same-lots of fuel.
as i havent changed the map sensor do you think it could be at fault.the pipe and all the wires are on it and seem ok.
is there any way to check the map sensor as i dont have another to try?
thank you all
jay
wowk
Mar 30, 2021 07:49 PM
20/20 vision
Sep 29, 2015 09:25 PM
