Ipod help :wall:
Anyone got one?
I have just bought a 60Gb photo one, and cant find anywhere in the instructions how long the first charge cycle should be.. Anyone know? I have no way of telling how far charged it is, as all I can see on the screen is the apple screen saver and it wont turn on
I'd be gratefull if anyone could help.
Mark
Mark
Originally Posted by EssexBoyRacer
Doesnt it say in the instruction manual how to turn it on?
I think from what I remember any key turns on it?
Are you charging off the wall or from a USB port?
Trying to find out if on the initial charge, if it has to be charged up fully before you can switch it on?
if you've just got the apple logo it means the battery is dead...
I left my mini on charge overnight. I think I needed to plug it into the wall for an update after its done before it will work
Originally Posted by Fastmaul
Ok, stupid question...
Have you connected it to your computer yet?
Originally Posted by Mongo
Thanks for your help.
Fastmaul Which bit of NJ do you live in? I spent a weekend in Hoboken last year, fantastic place
So did it help? plugging in the iPod?
I'm going to have to phone Apple up... When I 1st got the iPod I plugged it into my PC and nothing happened. I went through the CD, however when I got to the formatting section the PC did'nt identify with the iPod. When it did'nt format, I assumed that it had all ready been done, as the window said "iPod MAY require formatting"
Tried again from my laptop at home and the samething happened, however now I can't even get the apple logo to appear on the screen
Thanks for your help all the same
i have a mini, charge it up & you should see a battery in the back ground which means its charging, i suggest you use the firewire charger first mate, it will charge far more better than a USB, but when i first had my mini about 8 months ago, i installed i tunes first & then it said connect the ipod to the computer using the USB lead so it can get some data of i tunes & then you should be done, charge it after, then put some tunes on to it, remember ipods dont play WMA. files so only MP3's
Just heard there was a gas explosion in NJ. You OK, was it far off?
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
paceo
Sep 25, 2015 08:05 PM
Si B
Sep 12, 2015 06:49 AM
