2wd/4wd Brakes
Old Dec 9, 2005 | 11:46 AM
Muzz's Avatar
Muzz
Default 2wd/4wd Brakes
I have fitted 4wd Cossie brakes to my MK6 Escort. In order to get the caliper to clear the disc i had to space them 6mm off the hub.
I know you can use 2wd discs in conjunction with 4wd calipers if they are mounted normally, was just wondering if i would be able to use the 2wd discs/4wd calipers with the calipers spaced?
Old Dec 9, 2005 | 11:49 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
i used spacers on my mk6 (3x 10mm washers on each stud lol) and they were fine
complete 4x4 setup, i think the 2wd discs are for the RST's but could be wrong
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
