Finally done it :D
Been messing about most of the day testing my router security......and quite frankly, it is shit
Been trying to crack a 64bit WEP key, and i've been testing it to see what the average number of IVs that are needed to crack it.
I tried 60,000 and that didn't work, then i tried 380,000 and it resulted in this
http://img389.imageshack.us/img389/1918/aircrack1uw.jpg
2 seconds to crack a WEP key from the .cap file
Great fun to play about with i tell thee
changing mine to wpa tonight
Then might have a go at this cracking myself
i have a few neighbours that insist on using channel 6, and i use channel 1 and 6, they should have the decency to all just use 11 and disturb each other instead of me.
The unprotected ones are on 11 in my neighbourhoud
What capturing program did you use ? and what did you use to get the code out of the cap file ?
WPA is much more secure than WEP
WEP = Wired Equvilant Privacy, which in short means 'WEP is about as safe as an ethernet jack on the front of your house
I used the auditor security CD (installed on HDD) It is absolutely packed with tools for WEP/WPA/Bluetooth cracking.
Find it here: www.remote-exploit.org
To crack WEP is rather simple, just set your wifi card to monitor mode, run airodump to start capturing IV's to a .cap file, then run aireplay to capture a packet on the network, and replay it tricking the router into thinking its an authentic request from a network computer.
That aggitates the router to send out IV's at the rate of 1000 every 10 seconds or so, but if you are cracking a router with loads of traffic, it can be faster
Once you have about 300,000 Iv's that should be enough for 64bit WEP and for 128bit i would wait till i had 700,000 before attempting to crack it.
Anyway, Load the .cap file with Aircrack and let it do the work for you
I;m sure you don't need to be told that this stuff is highly illigal, so this information i am giving is for network administrators who wish to test their own network security
P.s Ballin, what you mean?
'I used the auditor security CD (installed on HDD) It is absolutely packed with tools for WEP/WPA/Bluetooth cracking.
Originally Posted by Mr.Manchester
fudge factor?
Originally Posted by Frogford
and where can I download this aircrack ? just so i can test my network you understand.
Depending on which chipset your wifi card has, you will need to download the right ISO
All the tools you need are in the auditor security collection CD
