Cossie ECU Voltage
Old Dec 8, 2005 | 07:54 PM
Neil S's Avatar
Neil S
Default Cossie ECU Voltage
With my engine running, my SECS monitor shows around 12.7V. I've confirmed this with a meter. Is this sufficient for the ECU, or should I have more (I gather that the ECU voltage has an effect on the fuelling).
I should also add that the voltage at the battery is 'only' 13.2-13.3V.
The voltage between the alternator casing and the output wire is a tad over 14V. Between the battery earth and the alternator output is the same, so I guess the earth is all good
Am I right in thinking that the only things that can cause this is bad wiring between the alternator and battery +ve, or the vehicle systems drain?
Am I making work for myself, or am I likely to have some kind of problem?
Any pointers would be ace!
Neil.
Old Dec 8, 2005 | 09:07 PM
Stu @ M Developments's Avatar
PassionFords Creator
Too Low IMO.
Wants to be battery voltage there really, but battery voltage should also be around the 14mark or at minimum 13.7 with electrics all off.
Look at teh battery "Fusible link tails" They look like 2 small crappy burnt out wires.... follow them 6" and learn that they are the main fusebox feeds!! Dead Common.
Old Dec 9, 2005 | 07:19 AM
Neil S's Avatar
Neil S
Yeah, I had fun soldering new ones of those in last year!
I'll keep poking, see what I can find
Neil.
Old Dec 9, 2005 | 01:53 PM
Neil S's Avatar
Neil S
Does anybody else have any input on this?
How can the condition of the fusible links affect battery voltage?
Neil.
Old Dec 9, 2005 | 01:54 PM
Neil.
Cause the voltage is going up them before it gets to the ECU mate
Replace them with a proper bit of wire and a decent seperate huse holder located by the battery
Old Dec 9, 2005 | 05:03 PM
Neil S's Avatar
Neil S
I meant BATTERY voltage, i.e. measured at the battery
I can see that the fusible links are a likely cause of the drop to the ECU, thing is, this ECU voltage is only about 0.5V less than battery. I repaired them last year, but I'm thinking that your way might be a useful mod
I've run a jump lead from the alternator to the battery positive tonight, this didnt affect the voltage at all. I can't see how the battery voltage is so far down from the alternator voltage
The only way I can imagine it is that the rest of the vehicle electrics are dropping the voltage at the battery, or that the battery is poor...
Cheers for the input Chip
Neil.
Old Dec 9, 2005 | 05:05 PM
DaveEscos's Avatar
DaveEscos
look at the alternator as well..
i think mines on its way out..
I have an optima top bollock battery and used to see 13.9's to 14's on my secs..
now im only getting 13.4's
trivial I know.. but i prefer it higher!
Old Dec 9, 2005 | 05:06 PM
Neil S's Avatar
Neil S
Alternator voltage is just over 14V Dave
Neil.
Old Dec 9, 2005 | 05:07 PM
DaveEscos's Avatar
DaveEscos
oops, didnt see that
Old Dec 9, 2005 | 05:10 PM
Neil S's Avatar
Neil S
No bother
At least you tried
Neil.
Old Dec 9, 2005 | 05:41 PM
Redkop's Avatar
Redkop
Two recent threads
https://passionford.com/forum/viewto...843&highlight=
https://passionford.com/forum/viewto...888&highlight=
Old Dec 9, 2005 | 06:44 PM
Matt's Avatar
Matt
neil, not sure how relevant it is, and i know shit all about electrics before you ask but mine sees 14.1 at the ecu according to the secs monitor when its running so based on that fact alone....too low lol
stu, you'll be able to elaborate more on the ecu compensating the fuelling for voltage drop, mine went banana's with the old wiring loom, fuelling at idle was all over the place, voltage dropped a good 2 volts with all electrics on (fuse links smoked and burned out!!). only drops half a volt now since new loom and proper loom fuses. karl did tell me why having a stable voltage was soo much better but im fooked if i can remember his nev like techy waffle
Old Dec 9, 2005 | 06:52 PM
Neil S's Avatar
Neil S
Thanks Lynne - I had read those earlier this week, and am currently in the process of measuring the current draw
Matt - I think I'm headed towards re-wiring as per Karl and Chip. Any idea what/where Karl did, or could you find out?
Neil.
Old Dec 9, 2005 | 07:05 PM
Matt's Avatar
Matt
ding made me a new loom, then karl mapped it again, problem solved lol
Old Dec 9, 2005 | 07:27 PM
Smit's Avatar
Smit
The 60ft Launch King
Neil - For the sake of money for a new loom/alternator i'm going to keep an eye on your thread
Old Dec 9, 2005 | 07:32 PM
alan rainbow's Avatar
alan rainbow
https://passionford.com/forum/viewtopic.php?t=53903
take alook at this neil try the cable between alternator and battery mine was fooked and had the same problem and as stu says the links at the battery
Old Dec 9, 2005 | 09:07 PM
Neil S's Avatar
Neil S
Alan - I was looking for that post earlier!
I posted on there at the time as I had recently replaced one of the fusible links.
This time, I will strip the fooker right back and replace them all.
Soldering the large cables is a right ballache Reading that post brings it all back!
After some fiddling, The residual current with everything off (doors closed etc) is about 40mA. Also I have 13.5V @ the battery at idle with no load. I'm happy with this for now.
Next step is to get the ECU voltage as close as possible to this.
Thanks all for taking the time to read the post and put some thought into it!
Neil.
Old Dec 9, 2005 | 09:11 PM
Matt's Avatar
Matt
this needs a post about fuelling voltage compensation!
Old Dec 9, 2005 | 09:13 PM
Neil S's Avatar
Neil S
Agreed - I'd like to read the reason behind it!
Neil.
Old Dec 9, 2005 | 09:14 PM
Neil i can tell you what to do without a new loom, as long as its in good condition.
I have got 14.32 volts to the pump from an alternator creating 14.35
I aint posting ths though will tell you on msn.
So know what I am doing.
Old Dec 9, 2005 | 09:18 PM
Fiecos Dan's Avatar
Fiecos Dan
steve's back.
at my ecu, With dingy's loom i run 0.1 volt lower than @ the alternator.
and run same voltage @ fuel pump.
Old Dec 11, 2005 | 03:37 PM
Neil S's Avatar
Neil S
OK, I'm pretty clear with how to get the ECU voltage up now thanks to Dingy
Whilst checking the rest of the lives, I found this:
This is the wiring to the 3 ABS relays, they supply the ABS valve block!
Must have been done before I got the car
Another job!!
Neil.
Old Dec 11, 2005 | 03:58 PM
GARETH T's Avatar
GARETH T
as battery voltage drops, responce time of the injectors gets slower, so the ecu needs to allow for this! so one of calculations the ecu does too the fuel base figure is battery adder!
Old Dec 11, 2005 | 04:22 PM
DazC's Avatar
DazC
Battery Adder!? Is that an electric snake or something?
Old Dec 11, 2005 | 04:29 PM
GARETH T's Avatar
GARETH T
DazC
Fiecos Dan's Avatar
Fiecos Dan
Wot amount should the ecu be compensating?
i think wen mines runing with all the lights etc etc on, 13.4-6volts @ ecu, inj's and fuel pump.
wot % should the fulein be changed if voltage goes down to 12.5volts?
Old Dec 12, 2005 | 07:22 AM
Neil S's Avatar
Neil S
Cool - Cheers Gareth
Neil.
Old Dec 12, 2005 | 08:36 AM
GARETH T's Avatar
GARETH T
im not sure how too work it back,, ive noticed on the secs ecu its 500 μs per volt
Old Dec 12, 2005 | 09:01 AM
Neil S's Avatar
Neil S
Not mega then?
Neil.
Old Dec 12, 2005 | 09:21 AM
GARETH T's Avatar
GARETH T
Not mega then?
Neil.
your so right aswell
Old Dec 12, 2005 | 09:24 AM
GARETH T's Avatar
GARETH T
edited cos im a dick
Old Dec 12, 2005 | 03:51 PM
Neil S's Avatar
Neil S
Edit it back cos now I look like the penis!
'We extend the injector duration by 500 mega seconds per volt, or 953 years, whichever is sooner'
Seriously though, just messing I always enjoy reading the techy stuff
Neil.
Old Dec 12, 2005 | 10:38 PM
GARETH T's Avatar
GARETH T
i cant believe i wrote M for milli,,, what a cock,, only done electronics for 12 years
Old Dec 16, 2005 | 05:18 PM
Neil S's Avatar
Neil S
OK, I've replaced the fusible links and now have 13V at the ECU. Battery Voltage is around 13.2V, so it's a bit better now
What should the alternator output be ideally?
Mine is 14V, sometimes just under.
Cheers!
Neil.
Old Dec 16, 2005 | 05:29 PM
Fiecos Dan's Avatar
Fiecos Dan
i believe 13.8 - 14.0 @ any rev's over idle, and even with all lights & heater on.
Old Jan 8, 2006 | 05:53 PM
trevCOSS's Avatar
trevCOSS
neil I have exactly the same reading as you did to start with! exept if i load the electrics i see about a 2v drop in all readings, did your fuseable links look dead mine look ok but i still suspect they may be to blame, what did you replace them with?
Old Jan 8, 2006 | 06:05 PM
SapphyMike's Avatar
SapphyMike
is it worth replacing my links to my battery while i have no engine in place? LOL
Old Jan 8, 2006 | 06:35 PM
pee vee's Avatar
pee vee
So these 'fuseable link tales'
are 2 wires coming off the battery to the fuse box??
sorry just adding things to my list of checks for my car
over the winter!!
Old Jan 8, 2006 | 08:06 PM
SapphyMike's Avatar
SapphyMike
bump
Old Jan 8, 2006 | 10:06 PM
Fiecos Dan's Avatar
Fiecos Dan
Well check voltage drop.
i test voltage at
alternator (usually 0.2 volt higher than battery
battery,ecu feed and outputs, fuel pump, inj. (all these about the same with in 0.1 volt, except fuel pump wen connected)
if you get low readings on something, put a better + and earth to it.
