exhaust help,i am stuck.....
Old Dec 8, 2005 | 11:07 AM
iggy gt4's Avatar
iggy gt4
Default exhaust help,i am stuck.....
i was taking off the old exhaust yesterday,and we had a bit of bother getting the turbo bracket off from under the car,it was getting wedged on the antiroll bar and the drive shaft,so it was a case of turning the wheels a bit and just moving it a bit at a time,any way we got the exhaust off,but i am guessing that when i go to put the new one on that the turbo bracket will be even bigger than the standard one,and it will be even more arkward to get it on from under the car,dont realy want to take the antiroll bar off so is there another way to do it????????or can u cet the first part of the exhaust on from the top???
any help would be great........
Old Dec 8, 2005 | 12:55 PM
iggy gt4's Avatar
iggy gt4
ah well here i go.........its gonna get cold as well....
Old Dec 8, 2005 | 04:37 PM
THE RADMAN's Avatar
THE RADMAN
presume you mean the flange? best bet is to use a pit or proper lift when fitting then you can get a better angle on the front pipe and thread it through,then slip the flange joint through the gap,its a very tight squeeze though so you will prob have to rotate the driveshaft still to help it on its way
Old Dec 8, 2005 | 08:57 PM
iggy gt4's Avatar
iggy gt4
goit it all done,the bit i thought was gonna be a pig was ok,it was getting it on the rubbers that was a mare,and with numb fingers it aint easy.........
but all done now but it dont sound a lot different,mind u i have not been any where in it yet.......
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
