series 1 Brakes
Yes we all know they are rubbish as standard
But what is the best way forward in getting better brakes on
a budget.
i've just been offerd some xr4i calipers and disc's
do they fit?
if not what other options are their?
any comments welcome as i don't know what option
to go for.
Thanks
Mark
a budget.
do they fit?
to go for.
Thanks
Mark
They are the same as S2's so yes.
If you had an extra £100 get a set of brackets (£40) off Clint Gaskins site
which will allow you to repostion your S2 callipers and install
285mm 2wd Cossie disc's (£60 any car accessory shop) which will totally transform your brakes.
I HAD 4X4 COSWORTH CALIPERS AND 2WD DISCS ON MY S1 AND THE BRAKES WERE SHIT HOT COST ME 60 NOTES FOR THE CALIPERS EBAY AND 35 NOTE FOR SOME DISCS FROM A MOTOR FACTORS
The S2 caliper on bracket set up, sits higher up the disc than the 4x4's do
which provides more torque/braking effect. Have a look at www.turbosport.co.uk for a more in depth explanation
Kiran1600E
11
Oct 2, 2015 11:35 AM
