E.F.I conversion, fuel problem and help needed !!
Old Sep 29, 2005 | 10:12 AM
david's Avatar
david
Default E.F.I conversion, fuel problem and help needed !!
Need a bit of help.
Done the conversion on my S2 with an EFI XR3i loom and OFAC ECU, using the original S2 tank and external pump so pulled what I beleive is the pump wiring ( 2 middle wires )from the 5 pin plug that does both sender and pump on the EFI and soldered on the original ends for the S2 pump. Problem is that the pump will prime but not run when cranking over, tried a different relay but no difference. It will pump when I run a direct live from the battery though .
Anyone had this problem before as its starting to do my head in now
Old Sep 29, 2005 | 10:19 AM
Graceland's Avatar
Graceland
Team HOTHOT!
the fuel pump relay on the EFI system is a sinle normally open item that is controlled via an output on the ECU - this wire is red with a blue trace (off the top of my head) and switches to earth for the relay.
Old Sep 29, 2005 | 12:07 PM
david's Avatar
david
Cool will try and track that one down, dont know what pin by any chance ?
Would a bad earth cause this then as thats what I suspected at first.
Old Sep 29, 2005 | 12:12 PM
Graceland's Avatar
Graceland
Team HOTHOT!
i aint the foggyest - all i remember it was on one of the corners
Old Sep 29, 2005 | 12:17 PM
david's Avatar
david
will have a hunt for it tonight mate
Old Sep 29, 2005 | 12:33 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
useless coont
Old Sep 29, 2005 | 09:06 PM
david's Avatar
david
useless coont
Agreed
Old Sep 29, 2005 | 09:12 PM
Rab's Avatar
Rab
Fucking superstar........
Originally Posted by david
useless coont
Agreed
Thirded..................
ginner
13
Aug 30, 2015 08:40 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
muffster
Aug 12, 2015 08:14 PM
col93saphcos
Aug 7, 2015 03:21 PM
