HELP, Heater problems on my Mondeo
Old Sep 29, 2005 | 10:08 AM
Spiky's Avatar
Spiky
Default HELP, Heater problems on my Mondeo
i have a problem with the heaters, in that they only work on setting no 4
settings 1,2 and 3 dont turn the fans on.
any ideas?????
Cola's Avatar
Cola
keep it on setting 4 then
Old Sep 29, 2005 | 10:09 AM
Spiky's Avatar
Spiky
Daveyboy's Avatar
Daveyboy
^^ that was me btw
Old Sep 29, 2005 | 10:10 AM
Spiky's Avatar
Spiky
Daveyboy,
but it's not the weekend????
thought you called Cola on weekends
Old Sep 29, 2005 | 10:11 AM
Spiky's Avatar
Spiky
Daveyboy,
also, i found my old powersteering bottle from my saff
no bracket though
u still want?
Daveyboy's Avatar
Daveyboy
its Colleen you tosser
Old Sep 29, 2005 | 10:13 AM
Daveyboy's Avatar
Daveyboy
woooo!! if you dont mind, that would be cool!! ta, tosser
We've rearranged karting dude, tis sat 8th now, just so you know no stress if you're too chicken though
Old Sep 29, 2005 | 10:14 AM
rsnissan's Avatar
rsnissan
resistor in switch is fooked............................................ new switch time
Old Sep 29, 2005 | 10:15 AM
Daveyboy's Avatar
Daveyboy
yeah, thats what i thought
Old Sep 29, 2005 | 10:18 AM
Spiky's Avatar
Spiky
as in switch on dash????
that it?? 5 min job???
Old Sep 29, 2005 | 10:19 AM
Spiky's Avatar
Spiky
i'm karting here on the 16th dude,
plus as i just bought a roof and roller door cost Ł1100 i'm kinda skint
pm me ya address to send it over dude , mates gonna have a look if he has abracket, but doubtful
Old Sep 29, 2005 | 10:24 AM
Daveyboy's Avatar
Daveyboy
No worries about karting dude, you'd have just sulked when i showed you up anyway
pm in progress
Old Sep 29, 2005 | 10:26 AM
Spiky's Avatar
Spiky
pm in progress
Old Sep 29, 2005 | 10:27 AM
rsnissan's Avatar
rsnissan
yep the actual switch that you turn....................never done on on a ford but dit it on my pulsar................just pulled the old one out and fitted the new one and that was it
Old Sep 29, 2005 | 10:28 AM
Daveyboy's Avatar
Daveyboy
im bricking it
Old Sep 29, 2005 | 10:35 AM
Spiky's Avatar
Spiky
rsnissan,
cheers dude, much apreciated
Daveyboy,
errm didn't you get FLOORED by me the other week WITH a witness
Old Sep 29, 2005 | 10:37 AM
Daveyboy's Avatar
Daveyboy
yeah, but i was on my way with or without your help anyway wasnt I
I will give you that one though
Old Sep 29, 2005 | 10:38 AM
Spiky's Avatar
Spiky
maybe you better start using this smilie
Old Sep 29, 2005 | 10:41 AM
Daveyboy's Avatar
Daveyboy
good one
Old Sep 29, 2005 | 10:42 AM
Rob M666SCC's Avatar
Rob M666SCC
theres a resistor in the heater box in the pass footwell, they normally melt the wiring too, about Ł25 from ford from memory, 5 min job
Old Sep 29, 2005 | 10:45 AM
Spiky's Avatar
Spiky
Rob@SCC Performance,
sweet cheers,
will have a look later
Old Sep 29, 2005 | 10:46 AM
3drstretch's Avatar
3drstretch
I have a P/S bracket if you want to send at the same time.
Old Sep 29, 2005 | 10:47 AM
Spiky's Avatar
Spiky
nice one dude
will come pick it up
Old Sep 29, 2005 | 10:48 AM
3drstretch's Avatar
3drstretch
Ok mate it over my house with my faulty PC.
Old Sep 29, 2005 | 10:49 AM
Spiky's Avatar
Spiky
DOH, walked into that one
Old Sep 29, 2005 | 10:50 AM
Daveyboy's Avatar
Daveyboy
you guys ROCK!!! will shout you both a beer at some point!
well actually, i might just shout at you spiky
3drstretch's Avatar
3drstretch
Your cable is still there as well
Old Sep 29, 2005 | 10:51 AM
Spiky's Avatar
Spiky
my cable
Daveyboy,
Old Sep 29, 2005 | 10:53 AM
3drstretch's Avatar
3drstretch
The cable you used to ghost my pc's i think.I dunno some special cable you brought down with you last time you fixed my PC
Old Sep 29, 2005 | 10:54 AM
foreigneRS's Avatar
foreigneRS
Testing the future
resistor cannot be in the switch - i would like to see a resistor that fits in there that is capable of passing over 15A
don't know where they are on a mondeo, but rob @ scc seems to. they're usuall somewhere that gets a bit of airflow though, cos they do expel quite a lot of heat.
Old Sep 29, 2005 | 10:58 AM
rsnissan's Avatar
rsnissan
Well my switch had a whole unit at the back of it. As said this was on a pulsar though so may well be different on a mondy.
maybe the switch itself was fooked on mine and not the resistor then?
Old Sep 29, 2005 | 11:00 AM
foreigneRS's Avatar
foreigneRS
Testing the future
not saying your wrong Andy, it's probably just that nissan control the fan speed in a different way rather than just dropping the voltage across a whacking great resistor
Old Sep 29, 2005 | 04:59 PM
Spiky's Avatar
Spiky
100% correct wiring melted too
Old Sep 29, 2005 | 06:42 PM
pugo's Avatar
pugo
fords do a kit its about Ł15 for the resistor and new cable with multi plug..........tis a known fault
Old Sep 29, 2005 | 06:59 PM
Ginge !'s Avatar
Ginge !
just finding my feet
thats true,spiky do ya have the mk3 shape mondeo with the screw hole in or the earlier one with the springs on show
its a actualluy design fault, sold one today actually, you need to solder the wires and not scotch lock em
the resistor is 1311115 i belive ( or close to that , sell about 4 a week )and the wiring i aint got a clue about, if the guy at the parts desk dont know what the wire is ask him to ask a memeber off staff on the back counter/workshop parts desk
the wire is about 7 quid odd and the resistor is 8 quid odd
Old Sep 29, 2005 | 07:01 PM
Spiky's Avatar
Spiky
my mondeo is N reg,
have no idea what you mean about Screw hole or spring
will pop to fords tomorrow and source one then solder it on
Old Sep 29, 2005 | 07:05 PM
Ginge !'s Avatar
Ginge !
spikey when ya take the resistor out theres 2 styles, the older style clips is and the newer style has a screw hole in it, ( thats the 1311115 with screw)
as its a N reg it could be either
take ya reg down and they will tell ya at fords
unless ya tell me how i can bypass the password at work and i can do it for ya tommorow
Old Sep 29, 2005 | 07:13 PM
Spiky's Avatar
Spiky
ok, to say confusion, just went out and took pics
i'm assuming this is the correct part????
Old Sep 29, 2005 | 08:53 PM
THE RADMAN's Avatar
THE RADMAN
identical to the one i did in my dads car a few months back,got mine from scrappy,fits nicely in pocket,lol
