avgas
Old Sep 28, 2005 | 04:52 PM
choppa's Avatar
choppa
Default avgas
avgas is a petroleum type fuel with 108 octane, used in older airoplane piston engines. im assuming this is cos of the thinner air at altitude. anyway does anyone know where to get any? ?
Old Sep 28, 2005 | 04:56 PM
EIL132's Avatar
EIL132
You'll be able to buy it from an airfield
http://www.thehangar.co.uk/fuel/fuel.shtml
Old Sep 28, 2005 | 05:02 PM
big_wig_074's Avatar
big_wig_074
please tell me youre not thinking of running a car on this? it will run like a bag of shite and melt!
Old Sep 28, 2005 | 05:15 PM
choppa's Avatar
choppa
ok i get ya point, its a bad idea. safe.
Old Sep 28, 2005 | 05:22 PM
big_wig_074
i know a few people who did this and it kills engines! but you CAN run a diesel on avtur!
Old Sep 28, 2005 | 05:36 PM
terrytennick's Avatar
terrytennick
aye most of the lads in work run thier cars on avtur
not a lot of lubricant in it mind. but at 0 pence a litre you cant complain
Old Sep 28, 2005 | 05:38 PM
EscortWRC's Avatar
EscortWRC
AvGas in a car is a bad idea
Old Sep 28, 2005 | 05:39 PM
choppa's Avatar
choppa
i can get plenty of that but i dont have a diesel, unfortunately. does it wear it out noticably then?
Old Sep 28, 2005 | 05:49 PM
terrytennick
not all that bad. most guys i know run 50/50 mixes or add a bit of some treatment stuff that they reckon works quite well
avtur is just like cheap badly refined diesel essentially anyway so id imagine its not too far off what youd find in really shonky petrol stations.
ya cant run a normal motor on it tho
Old Sep 28, 2005 | 05:55 PM
choppa's Avatar
choppa
really, i thought it was quite a high quality, being that its used in flying tin cans continuously. oh well. cheers anyway
Old Sep 28, 2005 | 06:00 PM
big_wig_074
aircraft fuels have to have VERY different properties to car fuels so thats why theyre not really compatible,a plane has to not blow up when it crashes at 300+ mph etc....... it also has to run at high altitude amongst other things
Old Sep 28, 2005 | 06:36 PM
choppa's Avatar
choppa
true, true. didnt think of that
Old Sep 28, 2005 | 06:52 PM
terrytennick
the high altitude isnt really an issue, the tanks are pressurised so the fuel wont boil. and a bit of Fuel system icing inhibitor (FSII) deals with the temperature. (combined wth the heated fuel recirc from the engines)
Thing is gas turbines will run on pretty much anything (up to and including coal dust), so the fuel only really has to meet certain standards ie flamability, corrosion/lubrication issues, and freezing. other than that its as cheap as humanly possible.
you honestly think the aviation industry would be paying for expensive well refined high quality fuels (let alone the military)
SE England
May 1, 2010 09:09 PM
RSlew
Jul 7, 2008 06:14 AM
mrviper
18
Feb 28, 2006 05:21 PM
