What kinda oil breather you using on your cosworth
Hi all .. as above, kinda oil breathers yous all using on your cosworths??
Any recomendations as to the best ones or are the all pretty much the same??
Any pics you can poct would be appreciated.
Thanks
Jam
Thanks
Jam
Im running the GGR/Tarcal item and Catch tank, plus threaded unions and stainless braided hosing, it weighs in at somewhere in the region of 8-900 quid
I have removed the flame trap it breaths from both sides of the block, to the top of the breather, the bottom of the breather returns to sump (modified) below oil level, a third port on the top of the breather goes to a catch tank on innner wing this vents to atmosphere below the car....
for extensive pics see the link in my sig ... I would also search this subject using the search option as its been discussed quite a few times
Originally Posted by Matt
its a tarcal tank
done over in a crackly dried spunk effect finish
JoeyBoyden
Aug 18, 2015 10:52 PM
Aug 14, 2015 07:29 AM
