Zetec turbo options....
Freddy_mercury_magic,
set of ian howell steel rods and cp racin pistons! Ł1250! slight portin to the head with standard valves! ian spec piper cams! get the head modded for rst exhaust manifold! and conversion plate to take frst inlet! a bit of ofac managment with ian spec injectors and chip! t34! happy days!
no im not biast! he s a top bloke who s very knolegeable! and dont mess people about!
Originally Posted by bassboy
radders would it be possible to take the Cossie TB off ur hands?
bassboy
bassboy
PM me when your about
I'll get back asap, bearing in mind im away with work till thursday so dont know what net access i have when im away!
Will try my best
Cheers for repy tho
Is Ian part of/owner Fiesta Frenzy/AREA 21 ??
Thanks again
Radleigh
Originally Posted by Ferd
GEARBOX
350bhp nice BUT were you going to get a box to take all that power?
Ferd
Ferd
turbocabs,
the box in a st170 is a getrag 6 speed! weights a ton and even with a ton of vasaline still wont fit! oh and its cable operated! fookin nightmare!!!!!
GEARBOX
Ferd
Ferd
Engine
zoo motorsport built 2.0zvh eagle steel rods je pistons 7:8:1 compression ratio
David Newman custom cam
Pumaracing 45mm valve race spec larger insert cvh head with custom double valve springs
Gt25/40r 0.64 dual roller bearing turbo Simpsons race exhausts tubular manifold hks filter forget the t34 too laggy and old school my Previous turbo was a t34 0.63 exhaust
Zoo three inch exhaust system from the turbo back
Zoo turbo pre-rad and oil cooler with remote oil filter
Zoo spoon style inlet manifold with 45mm ram jets
Grs fm cooler grs 520mm rad
Uprated escort cosworth fuel pump
S8 ecu running coil pack, closed loop lamba
750cc injectors as well as supplying more fuel then my old dark greens these are a much superior injector due to the spray pattern coming from six port hole nozzles instead of one for better fuel atomization. These supply 56cc less then eight greens.
Zoo group a engine mounts and gearbox cradle. This what I can remember so far.
Transmission
Cts stage two plus gearbox with shot peened & polished gears
Helix six paddle clutch extra heavy duty cover
Zoo hydraulic clutch
Brakes
Hi-spec Wilwood four pot calipers 300mm discs alloy bells
Hi-spec 300mm rear brake conversion alloy bells
Zoo Wilwood pedal box conversion triple master cylinders brake biased valve
Suspension
Avo coilovers
Zoo rose jointed adjustable rear beam
Zoo adjustable rose jointed lower arms for camber & castor
Wizard of nos 100 shot direct port nitrous & holley progressive controller every turbo charged car should run nos there so many benefits
Once run in Karl Norris will be doing the mapping @ 2bar ready for Santa pod 15th October on my old spec L8 ecu pectel 2.1zvh 311bhp @ 5960 and 296fbt but could only run 19 psi due to injectors where at Maximum duty cycle ź 13.3 @ 113 mph
If you don't fancy building the engine yourself use Ian Howell at Fiesta Frenzy as all the other tuners ring him for advice on the zetec anyway.
Steel rods, forged pistons, proper inlet manifold, bit of head work and plenty of boost should see 350bhp
I would personally go for a GT28RS with a .64 T3 exhaust housing
Speak to Grant at AET turbo's, he's your man for turbo's
Same sort of money but alot better spool up and drivability.
any ideas on a price for this?
thanks
gus
thanks
gus
Reservoirs x3
master cylinders x4
Braided plus fittings throughout the car
Biased valve
zoo custom bracket to fit pedal box to car took six hours to make
zoo custom bracket for the Hydraulic clutch
