rs turbo over heating problem
Old Sep 17, 2005 | 08:02 PM
ford crazy's Avatar
ford crazy
Default rs turbo over heating problem
she starts fine and runs fine
but the temp gauge only comes up just into white
when i remove water filler cap water over flows
could this be a faulty thermostat sender or is it the head gasket
Old Sep 17, 2005 | 08:18 PM
Rallyesport's Avatar
Rallyesport
Don't remove the filler cap, the system are under pressure. The boiling point of the water will be higher if the system is under pressure. When you remove it, the pressure will drop and the water will instantly boil.
Old Sep 19, 2005 | 10:05 AM
adamS2RST's Avatar
adamS2RST
As mentioned they run a pressurised system. Is the fan kicking in at all? Could be a possible dodgy temp sender or a thermostat problem.
Old Sep 19, 2005 | 10:13 AM
mart.rs's Avatar
mart.rs
sounds to me like the fan switch is not functioning! get a hair clip or somthing like it and pull off the plug that goes to switch stick the hair clip in the two terminals so that you are by passing the switch to run parallell! if the motor kicks in then the fans ok and you ,just need a new switch!
If however nothing happens then there could be a fault with the fan
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
druidgetafix
Aug 15, 2015 10:22 AM
track.focus'd
Aug 12, 2015 05:53 PM
