Hi my s2 is smoking quite bad, at first it only used to smoke in the mornings and then would clear straight away so i thought it was valve stem oil seals. But more recently it has started to smoke all the time mainly on hard acceleration and even a bit on idle. So some help is needed in solving the problem, any help would be great thanks......
