S2 Bonnet
the bonnet on my s2 seems really lose. when driving down the road i can see it lifting up and it scares the shit out of me!!
been told its a common problem so wondering what is the common fix for it??
cheers
cheers
You need to adjust the treaded part on the bonnet that the spring surrounds,this is the part that sits into the catch on the slam panal,it has a mushroom shaped head .You will see it has a big lock nut at the top,loosen this nut,at the mushroom shaped end theres a slot to put a screw driver in,turn the whole lot 2 complete turns clockwise,shut bonnet and see is the bonnet still loose.If it is turn it another 2 complete turns and so on until the bonnet no longer moves.Then tighten up the lock nut and job finished.Regards Micky
As above.
Had a bonnet round the windscreen on my S2 though and it ain't fookin funny. Hence the bonnet pins on her now
Not keen on the looks but at least I can thrash it without worrying about it happening again
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Adam Graham
Sep 6, 2015 06:04 AM
