EFI 1900CVH [BLOCK ONLY] IS IT A STRAIGHT SWAP
Old Sep 9, 2005 | 11:22 AM
Jay R's Avatar
Jay R
Default EFI 1900CVH [BLOCK ONLY] IS IT A STRAIGHT SWAP
Hi all just wonderd is it a straight swap from my standard S2 bottom end to 1900 efi cvh turbo bottom end out of FRST ?
Old Sep 9, 2005 | 08:51 PM
1.9s1's Avatar
1.9s1
yep straight swap. use FRST flywheel though incase you ever decide to go efi management, will save lots of hasstle if you do.
Old Sep 9, 2005 | 11:27 PM
nigel b's Avatar
nigel b
the rods are weaker than cadburys and the pistons are poor quality so dont expect to use loadsa boost
Old Sep 10, 2005 | 11:43 AM
Jay R's Avatar
Jay R
Uprated rods and pistons so shoud be ok as regarding the flywheel does the S2 clutch fit cheers
Old Sep 10, 2005 | 11:45 AM
Moonie's Avatar
Moonie
Yup the clutch will fit ok, they are both 220mm diameter.
Old Sep 10, 2005 | 11:57 AM
Jay R's Avatar
Jay R
Cheers lads
Old Sep 14, 2005 | 07:12 PM
jeffescortlx's Avatar
jeffescortlx
Just how much power is it good for? What is the breaking point?
gcfcos
59
Oct 6, 2015 05:04 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
