timming a kent cam
Old Sep 7, 2005 | 10:02 PM
Piinko-RS's Avatar
Piinko-RS
Default timming a kent cam
just fitted a kent cam in my s2 rst with springs etc its a cvh 34 . just wondering what i should set the ignition timing to its says in the haynes manual 12 degrees btdc but will that still apply to the kent cam ?
it isnt chipped but has a ss exhaust kn -31 act ..
thanks for any help .
Old Sep 7, 2005 | 10:07 PM
Rick's Avatar
Rick
You may get away with a little more, but unless u know what ur doing it could pink and melt ur engine. I'd leave it as it is.
Old Sep 7, 2005 | 10:11 PM
GrimmeRS2K's Avatar
GrimmeRS2K
mine is 12 degress, and i use the kent 34, runs fine.
Old Sep 7, 2005 | 10:57 PM
Piinko-RS's Avatar
Piinko-RS
thanks for the help guys
Old Sep 8, 2005 | 09:03 AM
Rallyesport's Avatar
Rallyesport
It's the lift timing you need to time correctly.
Old Sep 8, 2005 | 09:36 AM
Piinko-RS's Avatar
Piinko-RS
ive timed the lift timing with no1 pot at 119 and the no1 inlet valve at full lift its basicly the ignition timing i was after, but grimmeRST has his set to 12 so i will set it to that , till it goes to get chipped
Old Sep 10, 2005 | 04:09 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
The best way to time a Kent Cam, is to time exactly how long it takes to leave your hand and land in the bin.
Utter shit cams in my opinion.
Old Sep 10, 2005 | 06:54 PM
Rick's Avatar
Rick
It's the castings, they seem to vary in quality. I had one which did 20k, and had NO signs of wear. On another engine, it lasted a week
Old Sep 10, 2005 | 10:02 PM
Rab's Avatar
Rab
Fucking superstar........
Piper, Newman, Shrick all made good cams.
Old Sep 10, 2005 | 11:17 PM
dave_y's Avatar
dave_y
they can't be much worse than standard cams though...
Old Sep 11, 2005 | 12:08 AM
Combi_Chris's Avatar
Combi_Chris
the guys down at engine advantages seem to think other wise
Old Sep 11, 2005 | 08:39 AM
Tony Turbo's Avatar
Tony Turbo
Good for them. Alot of people like them, however, I would rather not have a new engine full of swarf and a knackered cam after a couple of hundred miles. Seen it lots of times from Kent Cams.
The standard cam is a good cam
Old Sep 11, 2005 | 09:51 AM
tubbykev's Avatar
tubbykev
i have gone for a piper 285T cam. Im running about 18psi at the min and thats fine. didnt want the wilder 285T2 cam, as i didnt want to sacrifice lower down power and driveability
Old Sep 11, 2005 | 12:28 PM
Rab's Avatar
Rab
I chose a standard one. Don't want to spoil drivability.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
