Fan override help please peeps . . . .
is it just a switch to control it when u like or permanately? either way why would u want to do this it will just tire out your fan can result in your fan motor getting fooked or your fuse box relays burning out, leave things the way they were
Just to bring it on when stuck in traffic and temp starts to rise instead of waitin for thermostat which can become unreliable with age. Just for piece of mind.
Not too sure to be honest mate, but it is a good idea. I had it done on my S2 and it's in the S1..like you say: just for piece of mind.
sufsRS, I think he means on a switch. If it was on perm, then it would take ages for the car to warm up, and there would be no need for the fan to run when the car is travelling, so a waste of time. I don't think that it would increase the tiring out of the fan by a great deal neither (unless it was perm on) as all it is doing is switching it on slightly earlier than it *may* already cut in at. More of a safe guard so that you can decide when you want the fan on. As said by Dry, the therms can become unreliable with age, so why risk it. I think it's a good, easy, cheap & worthwhile mod.
Sorry mate, meant to reply on weds, but forgot
Went out to the car & checked it for you. If you try to hand-spin the fan, it only moves a few 'blades' worth & is quite stiff. When the fans is switched on, then off, it continues to spin for around 2 seconds before stopping.
I don't think that you can lube then up as I'm sure they are a sealed unit: but could be wrong: I've never taken one apart, so you might be able to.
As for wiring: next to the therm housing there is a plug. This is the original fan switch wiring. You need to break into this & add two wires then run them into the dash area & fit your switch. In the S2 I used a simple toggle switch, but the S1 already had one fitted. See pic: switch next to the foglight one. Not sure what the switch is off the, as it has a fan pic on it.
I take it your talking about a std fan?
Its def worth doing tho ..ive fitted a cossie fan switch on mine but for sum reason its burnt out after like 3 months so was lucky i did have the in car switch
Should bring it down, yeh..depends how hard you've been running the car tho and if you are still driving at lower speeds will bring it down a lot quicker than stood idling. (Slower reduction as it is still getting hot in there even tho the fan is blowing on it)
I had switch in car, was great! Used to just switch it when approaching traffic, never got to hot at all then! Rather than sitting in traffic with your eyes glaring at the guage making sure the fan is going to cut in!!!
got the same on mine switch to turn on or off was working well but not been working as well recentlly had to cut the wires to change the turbo, now ive wired them back the car seems to overheat was wondering which way the fan is suppose to spin clockwise or anti clockwise.
got one on mine too, you dont need to run 2 wires from the fan switch, just the 1 will do, run it to an overide switch that switches to any decent ground point behind dash and provided your connected to the right side of fan switch the overide will controll your fan. if you then also run the switched ground to a flashing l.e.d with a fused ign + you will know when your fan is on wether you've overridden it or not
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
