Trying 2fit 2wd cossie 4 pot calipers on 2 my s1
Old Sep 3, 2005 | 05:29 PM
s1kid's Avatar
s1kid
Default Trying 2fit 2wd cossie 4 pot calipers on 2 my s1
Hi does anyone no anybody that has done this conversion?
As i have a set of calipers off a 2wd cosworth have thought about putting them on for a while,but a few people have mentioned a problem with clearing i wonderd if this was true as i have a set of 16" and wasnt sure if this made a diffrence?
Any info on any addidonal brackets or spacers needed would be great.
Please help.
Old Sep 3, 2005 | 05:59 PM
addiction's Avatar
addiction
you need to get 4mm machined off the inner face of the mounting lugs,also you will need to some banjo fittings for the flexies cos they come in at a different angle!
Old Sep 3, 2005 | 06:36 PM
Red16's Avatar
Red16
replied on the other thrwad you started, same as said above
Old Sep 3, 2005 | 09:00 PM
Wazzzer's Avatar
Wazzzer
plus you may have a prob with wheel clearance against aftermarket wheels, sorted with a 5mm spacer though
Old Sep 4, 2005 | 01:21 AM
wildheart's Avatar
wildheart
mike rainbird sells some of the parts needed
155lee
Oct 27, 2015 04:55 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
locum8
Sep 14, 2015 08:45 PM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
