saff 2wd cosworth problem
Old Aug 2, 2005 | 08:08 PM
rossco22's Avatar
rossco22
Default saff 2wd cosworth problem
Hi, theres seem to have alot of play in my steering when u turn the steering wheel side to side theres a couple of inches of movement either side before the front wheels move, when your driving at speed or down a country lane etc its very off putting! any ideas whats wrong? just had the tracking an balanceing done but no improvement, could it be the steering rack thats playing up or a bush of some sort?
If its the rack is it a big job? looks fairly tight?
thanks in advance...
Old Aug 2, 2005 | 08:15 PM
RSandy's Avatar
RSandy
i dnt kno anythin about the steerin rack set up on a cossie, but frm experience on my s2 then yeh, play in the steerin tends to indicate a dead rack, in ur case a very badly dead rack!!!!
Old Aug 2, 2005 | 09:39 PM
Alvyn's Avatar
Alvyn
make sure the bolts that hold the rack to the cross member are tight
Old Aug 2, 2005 | 10:36 PM
daz1968's Avatar
daz1968
I would check the steering coupler first, as if this wears it can cause this, had this on a mk3 fiesta, was easy and cheap to fix
Old Aug 3, 2005 | 06:10 AM
rossco22's Avatar
rossco22
Thanks for your replys guys, Daz is the steering coupler like a flat rubber donut that joins the rack half way up?
Anutternutter
Aug 21, 2015 06:07 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
James Porter
Aug 14, 2015 12:43 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
