clutch prob on s2..help!!!!!
just posted this in general room,but really need help had a problem a while ago where by i couldnt get my car into gear at all,so fitted a new clutch ,cable and box but to no avail
now its still doing it,all tho i have been told did i adjust the the clutch pedal properly????,as it does seem very,very light for a clutch pedal..........can anyone help!!!!!
might be that the clutch quadrant on the pedal has gone. i couldnt get mine in gear after fitting an ap 4 paddle, so had to use a quadrant and adjustable pedal from a later escort to bring the bite up off the floor.
A bitch to fit them though.
Best to take the seat out, put something comfy on the floor and lie on your back to do it. Make a real good note of where all the spacers go as well before you strip it out. And make sure you have some good long nosed pliers to pull the retaining clips off and put them back on again.
Did mine with the dash all out and it was still a sod!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
