misfire on erst
Old Jul 28, 2005 | 09:49 PM
jonesymk2's Avatar
jonesymk2
Default misfire on erst
ive got a misfire on my erst estate,it was running 18psi when i had the engine in my s2 erst then it stated playing up when i swapped it into the estate,ive turned the boost down 2 13psi now and it misfires a bit in 1st and 2nd a little bit but not so much or atall in the other gears,i was thinking it might be fuelling problems but its using a bit of water aswell now so could that add 2 the problem if the head gaskets gone
j.hammond1
30
Oct 31, 2021 05:28 PM
Mc5506
Oct 5, 2015 09:57 PM
Brickhouse
Sep 21, 2015 11:00 AM
beller
Sep 21, 2015 04:13 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
