MISFIRE PROBLEM
Old Jul 28, 2005 | 01:28 PM
tansey's Avatar
tansey
Default MISFIRE PROBLEM
Right i was wondering if anyone can help as i feel like punching my car! the problem is that when its starts come under load (ie when the boost kicks in)it just misfires big time and the rev counter starts flicking all over place it also some times cracks a loud bang out of exhaust and the most annoying thing is,is that it does not do the problem all the time but most of it. i took it some wher and he checked every thing under bonnet and he says that it is deffo nout under there,also have had the ecu checked and thats fine.so any ideas would be really apperacited as im going mad
Old Jul 28, 2005 | 01:38 PM
Mr Brannen's Avatar
Mr Brannen
Hello mate , I had that same problem a few months back, it had something to do with my fuel lines around the fuel Pump, one of the seals had perished , so the kid who does my car took it out and put it in a cup of boiling hot water then refitted it, and I swear to god it fucking worked,
If I read correctly it only happens when it comes on heavy boost, if so then that is exactly what happened to mine.
Hope its been a help and honestly I m teling the truth
Old Jul 28, 2005 | 01:40 PM
BAZZA BOY2's Avatar
BAZZA BOY2
I would look at the spark plugs first mate. check the gaps, it may be blowing out the spark.
i had the same prob and on number 4 the tip had broken off, lucky for me it came straight out the exhaust. changed the plugs and it runs like a dream...
Old Jul 28, 2005 | 01:44 PM
tansey's Avatar
tansey
ya if you just bring it into to the boost real gradually but dont floor it and dont take it more than 3 and a half or 4 thousand revs it does not really do it.but when you just deck it,it nearly puts you through window.but on saturday it only did it twice so i made the most of it but now its back to normal misfiring like i wont say what
Old Jul 28, 2005 | 01:45 PM
BAZZA BOY2's Avatar
BAZZA BOY2
def check the plugs mate.
Old Jul 28, 2005 | 01:48 PM
tansey's Avatar
tansey
already tried plugs, leads, dizzie, map sensor, coil and all that.thaks for the help though
Old Jul 28, 2005 | 01:49 PM
Mr Brannen's Avatar
Mr Brannen
Youre describing exactly what mine done, although the plugs would be a sensible first check.
Old Jul 28, 2005 | 01:50 PM
Mr Brannen's Avatar
Mr Brannen
The rounded bolts next to ya fuel pump are the ones I was on about!
Old Jul 28, 2005 | 02:00 PM
tansey's Avatar
tansey
im not no mechanic so i will tell neil at carwise uk as he is tryin to sort the problem out for me.thanks for your time in replying to this question. the plugs i tried were some qc 59`s but they were a bit old so i will whizz of and try some new ones today i think, does any one know what the plug gaps should be at all? just hopes it works
Old Jul 28, 2005 | 04:24 PM
tansey's Avatar
tansey
Well just went an bought some brand new qc 59`s and gapped them to 0.8 and guess what its still doing my head in so it was not them.
Old Aug 3, 2005 | 10:42 AM
tansey's Avatar
tansey
bttt
Old Aug 3, 2005 | 10:43 AM
tansey's Avatar
tansey
can some one move this post to the technical Q+A`s please
Old Aug 3, 2005 | 10:48 AM
Graceland's Avatar
Graceland
Team HOTHOT!
right - first things first
Check the crank position sensor on the front of the engine - make sure this is clean and free from debris, is not damaged and that the wiring is spot on.
Then check the Phase Sensor inside the distributor and make sure that this is gapped correctly.
if you have replaced the ht leads plugs, cap, rotor arm and coil then thats good but to me, i'd put money on it been the crank sensor breaking down.
Old Aug 4, 2005 | 09:25 PM
cossie550+'s Avatar
cossie550+
what was the outcome mate?
Old Aug 4, 2005 | 09:27 PM
pee vee's Avatar
pee vee
I HAD this exact problem
its the crank position sensor mate. (was on mine anyhow!)
check its clean and gapped right,, if it is, then buy a new one,
they are about Ł25
Old Aug 7, 2005 | 01:42 AM
tansey's Avatar
tansey
still no joy but only thing i have to do is try a new crank position sensor and then see what happens probably be same
Old Aug 7, 2005 | 01:54 AM
Stu @ M Developments's Avatar
PassionFords Creator
Bad connection in the plugs on the firewall are a 90% probability pal.
Failing that, run a new earth lead from plenum to battery and then battery to ignition amplifier.
Old Aug 7, 2005 | 01:59 AM
tansey's Avatar
tansey
to me mate thats a different language but i will let neil know n see what he says to me cheers again
Old Aug 7, 2005 | 05:14 AM
Dunccoss's Avatar
Dunccoss
mate it did this with me when i had the car and it turned out to be the main lead from the coil to the dizy was to close to the map sensor, have you moved the lead/ or if so make sure it not to close, hope that sorts it mate as this problem evern had tuners scratching there heads
Old Aug 7, 2005 | 06:41 AM
skiddley bop 4 pot's Avatar
skiddley bop 4 pot
check wires on phase sensor in dizzy , see there not cracked and touching together or dizzy wall
Old Aug 7, 2005 | 10:37 AM
richm's Avatar
richm
4x4?
The clue is in the mental dancing tacho
no harm checking the crank and phase sensors as suggested, but my 90% is on this too. 85% of it is on the multiplug nearest the battery with the thick wires in (we're talking about the three multiplugs on the bulkhead above the back of the engine) - split the connector and check that the pins are clean, then plug it in and out a few times. Do the other two as well. Also check the condition of the earth tag connections on the brown wires that bolt onto the plenum chamber, and if you can as Stu says make up a stout earth lead and run directly from battery negative to the point where the brown earth wires bolt on the plenum.
Also double check the connections to the ignition amplifier and coil.
Old Aug 8, 2005 | 12:33 PM
tansey's Avatar
tansey
richm yes it is a 4x4. dunc it was a bit close so just moved it now and will take it out soon and see if there is any joy.
Old Aug 8, 2005 | 12:44 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Are you using standard ford leads? does your set set up include green injectors and a 3 bar map sensor?
Matt
Old Aug 8, 2005 | 01:55 PM
tansey's Avatar
tansey
yes i am mate but the cars sorted now well it has been for about 15 miles anyway.never missed a beat n even starts better too.dunc i could kiss you right now if you were next to me.happy man now cheers
Old Aug 8, 2005 | 02:00 PM
tansey's Avatar
tansey
cheers everyone for the help though
Old Aug 8, 2005 | 02:31 PM
Neil S's Avatar
Neil S
Tansey - Does your car have a multicoloured cam cover?
No relevance to your post, but I think it's my mate's old car
If it is the same, it used to have a similar problem - think a new MAP sensor cured it
Neil.
Old Aug 8, 2005 | 03:17 PM
tansey's Avatar
tansey
neil s hollo. no it had a silver cam cover when i bought it but i bought it off dunc (dunccoss) who is the chairman of the northants group. i have just sorted the problem a few hours ago,the the ht lead was to close to the map sensor which fook knows how that would of been thought of if it was not for dunc.
Old Aug 8, 2005 | 03:41 PM
Neil S's Avatar
Neil S
Nah it's defo not my mate's old one then
Neil.
Old Aug 8, 2005 | 05:58 PM
Dunccoss's Avatar
Dunccoss
cheers glad its sorted, when it happened to me it was a bastard to find to me then cheers dunc
Old Aug 8, 2005 | 05:59 PM
Dunccoss's Avatar
Dunccoss
ps, no need to kiss me when you see me next OK
Old Aug 8, 2005 | 08:58 PM
tansey's Avatar
tansey
oh not even a little one.ha ha yaits been miss fireing now for about2 months maybe and it was realy f##king me off.felt like selling it at one point,but thats the joys of owning a ford i suppose.it feels mint now just in time for national day.cheers again dunc
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
