K-Reg 4x4 Saphire Cosworth 400BHP...
Sierra Cosworth 4x4 one of the last ones on K-Reg in Moondust Silver..
Running 400Bhp - Dyno Printout
Full engine build at 89,000 miles, done 105000 miles
light blue injectors, rs 500 cooler, new rad , new starter motor,cosworth forged pistons low comped 7.2, arp conrod bolts, fully balanced bottom end, new oil pump/water pump, Alcon 6 paddle clutch, BD 14 Inlet cam, Standard Exhaust cam, Ported and Polished pressure tested grpA gas flowed head, new guides and tappets cut in valves & seats 3rd angle valve seats, T34 Hybrid, New cambelt & tensioner, new cap & rotor arm, Samco hoses, Mongoose Exhaust, New Gearbox, Koni adjustables -25mm Springs, Polybushed, Chromed Strut brace and Engine bay, New Front pads , new rear discs and pads, Dot 4 Fluid, new Anti freeze, oil change every 3000 miles, boost gauge in piller pod, electric sunroof, Kenwood Multi changer,Cat 1 Alarm & imobiliser...
£8250 Tel:- 07855369009 or 01782 331821 Andy
[/img]
[/img]
Aug 14, 2015 07:29 AM
