erst fuel pump relay
Old Jul 24, 2005 | 09:12 PM
bassy_g's Avatar
bassy_g
Default erst fuel pump relay
my fuel pump relay seems to have a mind of its own
sometimes it works other times it doesent,although it runs every time bridged out.
ive tried different relays,another fuel pump,the fuel pump is also wired with a positive feed from the battery(all done correctley with relay,fused ect)seems if i move the pink relay wiring around it sometimes works,tried running a new earth from the pink relay,also checked the red/green wire to the ecu and thats fine,
ive ran out of ideas and patience with it now
Old Jul 25, 2005 | 09:28 AM
davidnormanuk's Avatar
davidnormanuk
Check to see if ones of the pins that the relay plugs into has moved. I had this problem with mine and I just replaced the whole connector by cutting and heat shrinking.
Dave
Old Jul 25, 2005 | 03:21 PM
bassy_g's Avatar
bassy_g
already tried mate,ive had also had a new connector on,to no avail
cheers
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
