problem cutting out.
Old Jul 24, 2005 | 02:29 PM
danxr2i's Avatar
danxr2i
Default problem cutting out.
i have a 1.6 8v efi and have just fitted a top fast road cam kit, when i come to junctions the revs drop right down to about 400-500 rpm and sometimes it cuts out. could it be a sensor problem? any help would be appreciated
Old Jul 24, 2005 | 04:00 PM
antony215's Avatar
antony215
Escort Rs Turbo
Take the carb off and clean it out i had the same problem with my efi did that and it was fine after. The round plate inside the carb gets stuck sometime's thats way they cut out
Old Jul 24, 2005 | 04:12 PM
danxr2i's Avatar
danxr2i
you mean the butterfly in the inlet manifold, i'll give it a go.
Old Jul 24, 2005 | 04:15 PM
antony215's Avatar
antony215
Escort Rs Turbo
Yeah thats it clean all the black shit out. thats why mine used to cut out
Old Jul 24, 2005 | 08:15 PM
AKRS1's Avatar
AKRS1
idle speed control valve could be a problem looks like a small tube with a blue ford sticker on it may be located on the inlet manifold or it may be on the air box itself on later cars
Old Jul 24, 2005 | 10:14 PM
sailorbob's Avatar
sailorbob
The VSS sensor can cause this problem, try reading the error codes.
Old Jul 24, 2005 | 11:16 PM
grease monkey's Avatar
grease monkey
its a good chance its the idle valve alright i would give it a clean aswell and see how it runnin then.
Old Jul 25, 2005 | 04:53 PM
danxr2i's Avatar
danxr2i
the idle control valve is'nt on the air box anymore, it's been cut off so a cone filter could be put on, could this be the problem? should there have been an adapter of some sort? i would'nt know cos it was like that when i bought the car.
Old Jul 25, 2005 | 07:13 PM
AKRS1's Avatar
AKRS1
no i think you still have the idle valve there but you are looking at it properly. Look at the inlet manifold where it says "EFI" then to the left of that there should be the idle valve that looks like a tube with a blue sticker on it. I had a orion efi with a fast road cam and it always idled rough but shouldnt cut out though. Maybe you could take a pic of your engine bay and we might be able to point it out for you
Old Jul 26, 2005 | 12:44 PM
antony215's Avatar
antony215
Escort Rs Turbo
Did you try what i said with the butterfly in the inlet manifold cos when i had the problem i changed everything ecu--idle valve--cps sensor--fule cutoff switch--ignition module everything i thought it would be and in the end it was that butterfly plate i know it sound stupid but give it a go and see i spent shit loads of money before i gave it a go now i wish i'd tryed that first pm me and let me know how you get on.
Old Jul 26, 2005 | 05:08 PM
danxr2i's Avatar
danxr2i
gave it a go seems to have worked.
Old Jul 26, 2005 | 05:30 PM
danxr2i's Avatar
danxr2i
does this help?
Old Jul 26, 2005 | 09:52 PM
AKRS1's Avatar
AKRS1
i have arrowed it but perhaps you should try cleaning inlet manifold first. To clean the idle valve you need to take the 2 screws off that hold it together but be careful not to tear the gasket apart as i dont think they are available anymore so you will have to use the same one and give it a clean out with some carb cleaner.
Old Jul 26, 2005 | 10:49 PM
danxr2i's Avatar
danxr2i
cheers mate i'll give it a go.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
routemaster
Sep 7, 2015 05:27 PM
hopper350
Sep 4, 2015 12:53 AM
