zetec turbo need help
can anyone tell me where is the best place to drill the oil pick up for the turbo also will the oil pump be ok or will it need changed,should i fit an oil cooler? thanks for any help
the oil feed to the turbo is taken from the oil pressure switch using a 'T' type adapter, its the oil return that needs drilling, as does a breather, some pics here, follow the links mate, lots of usefull info around http://www.fiestaturbo.com/phpBB/viewtopic.php?t=77570
