Fuel Computer & Electric mirrors Q.
Old Jul 11, 2005 | 10:48 PM
rs s2 87's Avatar
rs s2 87
Default Fuel Computer & Electric mirrors Q.
Hi,
Does anybody know, did the electronic fuel computer and electric mirrors come standard on the Series 2?
Thanks
Old Jul 12, 2005 | 05:11 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Fuel Comp was optional extra
Not 100% sure about leccy mirrors before '90 spec. After '90 spec leccy everything was standard, I think.
Old Jul 12, 2005 | 06:32 AM
rs s2 87's Avatar
rs s2 87
Cheers.
Do you reckon the wiring loom would of being the same? So it's a case of buying electric mirrors and conecting them up?
Old Jul 12, 2005 | 01:13 PM
Tony Turbo's Avatar
Tony Turbo
Yeah, the looms are the same, everything is just plug and play. I retro fitted a few things myself, everything was there on the loom.
Old Jul 12, 2005 | 01:14 PM
Tony Turbo's Avatar
Tony Turbo
What do you want to fit? I can tell you roughly where the plugs are.
The majority of them are behind the speedo pod, and slightly to the right
Old Jul 12, 2005 | 03:29 PM
rs s2 87's Avatar
rs s2 87
Fuel computer and elec mirrors.
Cheers Tony.
Old Jul 12, 2005 | 03:36 PM
Tony Turbo's Avatar
Tony Turbo
No probs mate. The fuel computer one is where I said, the mirror ones are by the doors I believe. Not sure about the mirrors
Old Jul 12, 2005 | 03:40 PM
Turbo-T34's Avatar
Turbo-T34
dont you have to have the sensors on the jetronic system first to be able to use the fuel computer?
Old Jul 12, 2005 | 09:48 PM
sufsRS's Avatar
sufsRS
for the fuel computer you will need alot of sensors etc more hassle then its worth to be honest
Old Jul 13, 2005 | 09:18 AM
Tony Turbo's Avatar
Tony Turbo
Yeah, you will need the speedo sensor and the fuel flow sensor which goes on the metering unit, the one in the tank is on all cars, that is under the rear seat.
I retro fitted my fuel computer and it always worked, I did miss it when I changed management, now it is an ACT gauge lol
Old Jul 13, 2005 | 09:21 AM
Turbo-T34's Avatar
Turbo-T34
the beeping of the computer annoys me the most hehe
Old Jul 13, 2005 | 09:46 AM
Tony Turbo's Avatar
Tony Turbo
Put some fuel in then
Old Jul 13, 2005 | 04:02 PM
Turbo-T34's Avatar
Turbo-T34
ahh jeez, do i have to?!?!
The annoying bit is when you turn on the car and it gives you the 3 beeps, 3 beeps for what? to tell you the car is on, to tell you its on? as if i`m blind AND i`m deaf!
i can see!!!!
oh well, never mind
Old Jul 13, 2005 | 04:49 PM
Wazzzer's Avatar
Wazzzer
Go up a scrappy and pull the dials out of an Orion Ghia, take the mirror switch out, and behind there should be a black plug with 2 connections (+/-) this is the mirror loom.
then just follow it to the doors, pull it all out and connect it to yours
Old Jul 14, 2005 | 09:01 PM
rs s2 87's Avatar
rs s2 87
Ta 4 that lads....
I will get onto it...
Old Aug 27, 2005 | 11:28 AM
P_is_for_Paul's Avatar
P_is_for_Paul
Coldo loves seamen
I have a 1990 G ERST which came with leccy mirrors, variable wiper stalk etc, but no fuel computer. I have just purchased one off ebay and have taken off the black plastic surround and cant see anything coming off the loom to connect the fuel computer to??? Its a tight wee space to try and find anything though! Will there be a multiplug there or am i wasting my time? Surely when the car was new and a fuel computer was chosen as an option a Ford technician never had to fit all new sensors to fit a computer?
Old Aug 28, 2005 | 02:36 PM
P_is_for_Paul
Coldo loves seamen
And what is this thing stuck to the back? I dont have this!! (This photo is off e-bay)
Old Aug 28, 2005 | 05:11 PM
gavintwopies's Avatar
gavintwopies
_________________
thats sumit to stop it from falling over while he took the picture
Old Aug 29, 2005 | 07:31 PM
P_is_for_Paul
Coldo loves seamen
I thought it was joined to the back!
Old Aug 30, 2005 | 07:22 AM
JesseT's Avatar
JesseT
I hope you didn't purchase just the display unit.
Old Aug 30, 2005 | 10:26 AM
Tony Turbo's Avatar
Tony Turbo
You need to loom, speed sensor and fuel flow sensor too...
Old Aug 30, 2005 | 10:32 AM
JesseT's Avatar
JesseT
Loom can always be made DIY, the speed sensor is the same as in practically all mk5 escorts, but the flow sensor... oh dear...
Old Aug 30, 2005 | 05:08 PM
Turbo-T34's Avatar
Turbo-T34
i would say if you aint got the loom for it, dont bother, more hassle than its worth
Old Aug 30, 2005 | 05:49 PM
P_is_for_Paul
Coldo loves seamen
Yeah just the display! Is the fuel flow sensor not plugged in the side of my metering unit? If its too much hassle i think i think i will just go with
AND
Old Aug 30, 2005 | 06:54 PM
JesseT's Avatar
JesseT
Not unless somebody has installed one afterwards.
S3an
Sep 26, 2015 11:39 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
S3an
13
Sep 13, 2015 10:01 AM
