FAO people running ap clutches
Old Jul 11, 2005 | 02:58 PM
james_birch's Avatar
james_birch
Default FAO people running ap clutches
Those of you running organic ap clutches did/have you done the pedal mod?!
my clutch has started to slip!
Old Jul 11, 2005 | 03:15 PM
AKRS1's Avatar
AKRS1
I bought a ap organic clutch 4 months ago and done the mk5 mod which only made a slight difference to no matter how much i adjusted the pedal and now 4 months later its started to slip. Been told to take it back out and give it back to ap to inspect.
Old Jul 11, 2005 | 03:37 PM
mart.rs's Avatar
mart.rs
mr birch how the devil are ya yep ive had clutch probs too mate at the mo mines sitting outside me flat with no box in on axle stands,blasted thing wouldnt go into gear at all!!
Old Jul 11, 2005 | 03:44 PM
swerv's Avatar
swerv
yes AP organic been in for over 2 years with the mk5 pedal mod , no problems.
Old Jul 11, 2005 | 04:07 PM
james_birch
im good thanks! just had the car rolling roaded at 219bhp and 222ft/lb and now the clutch is starting to give in!
Gunna have to stay off boost for a while!
Old Jul 11, 2005 | 04:53 PM
Moonie's Avatar
Moonie
The pedal mod will not prevent your clutch from slipping, all it does is pull more cable when the pedal is depressed to give improved release/gear change.
Old Jul 11, 2005 | 05:22 PM
gus's Avatar
gus
no pedal mod on mine and all is fine
Old Jul 11, 2005 | 08:32 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Andy and Dan have the organic clutch and have no pedal mod as far as I know.
What clutch you got at the moment?
Old Jul 12, 2005 | 03:45 AM
Melly's Avatar
Melly
I have the Helix organic clutch on mines. When the previous owner had it fitted he also had the mk5 pedal assembly put in but this leaves the clutch pedal sitting far too high for my liking. Is there a happy meduim.
Melly
Old Jul 12, 2005 | 12:32 PM
Combi_Chris's Avatar
Combi_Chris
NO i Didnt
Old Jul 13, 2005 | 07:04 AM
JesseT's Avatar
JesseT
S1's have a longer release bearing travel anyhow as compared to S2's because the lever is shorter in the box. Also the quadrant is the biggest one already. I haven't found any need for the pedal mod.
Old Jul 17, 2005 | 09:45 AM
wul young's Avatar
wul young
i run ap paddle,cp2015-8,didnt find the need to do pedal mod.
SmudgerByName
52
Jul 28, 2016 06:14 PM
neil18
Mar 14, 2016 01:08 PM
Chas
Sep 21, 2015 08:57 PM
ray barker
Aug 7, 2015 09:00 AM
