Is it best to.............
Old Jul 10, 2005 | 09:40 PM
GrimmeRS2K's Avatar
GrimmeRS2K
Default Is it best to.............
have your -31 actuator with loads of preload and not as much air bled out the via your bleed valve
or not as much preload, and alot of air bled out via the bleed valve
if u know what i mean, as my turbo is being inspected for possible overspeeding! after it blew up
i have mine as the first one, does it make any difference on turbo life?
its a stage 2, running 21 psi, holding 17-18psi erst
Had the turbo on for 3 months and it blew up the other day, got a new one coming under warranty on tuesday, but universal turbos said that the turbo was overspeeding coz of an air leak?, no air leak on my car, holds boost fine, the only thing i could think of is what i mean with too much preload
cheers
Old Jul 10, 2005 | 10:25 PM
radiant red's Avatar
radiant red
i can see what ya saying mate but is the turbo not gonna spin at the same rpm if coming to the same boost, one way or another? intresting that one
Old Jul 10, 2005 | 10:33 PM
GrimmeRS2K's Avatar
GrimmeRS2K
my -31 is quite wound in, with not much bleed valve adjustment, dont know much about turbos, but i hope someone reads this who does!, just dont wont to blow this turbo up, as cant see getting another free one!
im gonna try it the other way on tuesday when i get it back, with more bleed valve adjustment to see how it goes
