getting very hot
Old Jul 10, 2005 | 09:03 PM
1tub's Avatar
1tub
Default getting very hot
fitted pro alloy intercooler twin fan jobbie
its now getting well hot in traffic (really really hot even with the fans running and the heater on)
any other mods any one done to help keep it cool on a series one
ive got bonnet raiser blocks to go on . im obtaining a different fan switch drilled big holes in bumper and moved the number plate
does water wetter work and removeing the spot lights does that help(or not when stationary) or is a bigger rad and electric water pump
my only option
Old Jul 10, 2005 | 10:26 PM
GrimmeRS2K's Avatar
GrimmeRS2K
u have properly done what everybody else normally do, got the two wires to the fans the wrong way round causing the fans to suck rather than blow, change the wires around and it will be fine
Old Jul 21, 2005 | 09:33 PM
1tub's Avatar
1tub
nope checked that ,got the third fan fitted so ill go out when its hot and try again
Old Jul 22, 2005 | 01:19 AM
rs_daz's Avatar
rs_daz
3 fans wow..
I got 2 kenlows 10" and they work fine.
82 stat
cossie fan switch
hope ya sort it..
Old Jul 22, 2005 | 07:05 AM
Eagle's Avatar
Eagle
Super Moderator
you could always drill 2 x 2mm holes in the thermostat.. the part that lifts ..
this allows some water flow but isnot enough to effect the running.
Old Jul 24, 2005 | 08:30 PM
1tub's Avatar
1tub
ill give that a go cheers lad
Old Jul 24, 2005 | 08:36 PM
1tub's Avatar
1tub
three fans and it doesnt get hot in traffic
now i know it works ill get a proper fan that pulls ,rather than the standard one in reverse. also getting the right size to fit the room available
Fiddy
21
Sep 29, 2015 06:10 PM
PeterLucas
Sep 21, 2015 11:36 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
