engine is pinking! any ideas
Old Jul 10, 2005 | 03:16 PM
AJC's Avatar
AJC
Default engine is pinking! any ideas
just started doing it completely out of the blue
the car has a 5th injector on it and is only pinking at high boost and
high revs, so i thought that may be 5th were not working, but
its only just been fitted by Stu at MSD and it were fine till wednesday,
i was not going to use the car until it were sorted but went for a drive last
night and pulled up next to an s2 and thought sod it, 'go for it'
and there were no problems, but on way home it did it,
confused
well its getting new injectors on wednesday and is at MSD on the 18th,
i hope its sorted, any one had this problem, ideas to cause would
be great, thanks troops
Old Jul 10, 2005 | 09:23 PM
AJC's Avatar
AJC
anyone? pls
Old Jul 10, 2005 | 10:21 PM
GrimmeRS2K's Avatar
GrimmeRS2K
was it warmer than normal mate, causing your act's to be higher
also, the KE jetronic (if u use it) isnt the best fuel deliverly system around and can have a mind of its own sometime when running more than normal, mine does the same mate, and mines setup by a similar company to msd,
i had the fuel pressure mod though rather than a fifth injector and now and again i hear mine pink on high boost
i take it ur using a proper mf2 5th injector?
Old Jul 11, 2005 | 04:30 PM
AJC's Avatar
AJC
yes, the mf2 injector is the one i have, the engine was as normal i would say,
looks like i might have to go efi then
Old Jul 11, 2005 | 06:59 PM
Rs1's Avatar
Rs1
Too high a intake temp will cause pinking. Are you running the standard intercooler?
Too weak fuel mixture,you say you have a 5th so that should be fine.
Or bad igniton setting which is ecu controlled. Basically nothing you can check yourself unless you have a rolling road and gas tester handy.
Old Jul 11, 2005 | 07:06 PM
Rs1's Avatar
Rs1
Hold up,just re read your description. High boost high rpm may not be pinking. Could easily be lazy tappet,piston slap,small end or anything mechanical really. Is it a light rattle or a loud deep kind,lol. If it is pinking its more likly to do it when you going up hill or whenever the engine is under high loads(low rpm,high gear,100% throttle). Although i really dont recommend driving whilst thr car is pinking you could try it by going along @30-40mph in 5th then nail it,if its going to pink it'll do it way before you get near scary revs,once the boost comes in it should start rattling its nuts off tbh.
Old Jul 11, 2005 | 09:13 PM
TurboFlush's Avatar
TurboFlush
Is yours carbed?
carb and turbo = problems. but they can always be found. My mustang had issues with the fuel and when I got into the boost the computer would adjust timing, however there was not enough fuel so it would knock (pink). changed the secondary jet and fixed it good.
TF
Old Jul 11, 2005 | 09:20 PM
GrimmeRS2K's Avatar
GrimmeRS2K
carb, lol, its a fuel injection!
Old Jul 11, 2005 | 10:10 PM
AJC's Avatar
AJC
low rpm under load causes it to pink mate, did it tonight, i cant
see it being a mechanical rattle, engine just been rebuilt.
it can get sorted on the 18th hopefully,
thanks for the info
Old Jul 11, 2005 | 10:29 PM
DazC's Avatar
DazC
Just take it easy until Stu can look at it mate! It's only 6 days off the 18th so just take it easy on the car. Wonder if this hot weather is causing problems with the charge air temp sensor.
Old Jul 12, 2005 | 04:50 PM
AJC's Avatar
AJC
would make sense seeing that it only just started doing it.
Old Jul 13, 2005 | 12:08 AM
TurboFlush's Avatar
TurboFlush
old or crap gas will do it to...
Old Jul 13, 2005 | 09:26 AM
cossie604's Avatar
cossie604
Most prob the weather....my cossie is feeling well down on power at moment but fine 1st thing in morning on way to work And thats with a RS500 intercooler fitted up....gonna fit an act/afr display this week just so I can keep tabs on it all
Old Jul 13, 2005 | 05:37 PM
AJC's Avatar
AJC
petrol used is always optimax, the best
Old Jul 14, 2005 | 07:24 PM
XRTypeRS's Avatar
XRTypeRS
Im getting the same at the moment mate due to the heat, totally fine when im on the main road but once I get into town and sitting in traffic it seems to be getting heat soak and pinking under load at low revs when pulling away.
Am going to pop outside now actually and knock the timing back a couple of deg for time being just to be safe. Might also run some tests on my charge temp thermistor - maybe its dead
Old Jul 14, 2005 | 08:21 PM
TurboFlush's Avatar
TurboFlush
feed her more fuel.... throw flames out the arse!!!!
Old Jul 14, 2005 | 08:53 PM
XRTypeRS's Avatar
XRTypeRS
My AFR is already 13.3 on cruise and 11.5 on boost - enough fuel I think
Old Jul 16, 2005 | 08:10 AM
AJC's Avatar
AJC
cheers troops, it at MSD on monday so hopefully they will sort it, but saying that,
it aint done it for ages,
Old Jul 20, 2005 | 01:27 PM
MGTurbo's Avatar
MGTurbo
Do not ignore a dodgy batch of fuel. I've had it happen to mine in a similar situation and detailed on another thread, this was about a month ago. I chucked in extra fuel (simple on mine, just file the carb needle) and it was still there, i cant do the timing on mine because it's ECU controlled and the only thing that stopped it at the time was a dose of Millers octance booster. As you say it hasnt happened since, i would be looking at a one off situation. As you know what det sounds like you will be able to back off if it ever happens again. Wonder if anyone has ever claimed against a fuel company for detonation induced engine failure caused by their fuel being off... ???
Old Jul 21, 2005 | 05:19 PM
AJC's Avatar
AJC
not happened for ages now, but now i have turbo surge
Old Jul 21, 2005 | 05:56 PM
radiant red's Avatar
radiant red
what do you mean by turbo surge
Old Jul 21, 2005 | 08:26 PM
MGTurbo's Avatar
MGTurbo
Do mean mean boost creeping or boost spiking?
Old Jul 23, 2005 | 10:19 AM
AJC's Avatar
AJC
too much boost being created by the T4 comp wheel and the turbo not being big
enough to accomadate it, it only happens if i am going say 80 on m way
and i slowly put my foot down, so not that big of a deal, will get it sorted soon
Old Jul 23, 2005 | 03:50 PM
DazC's Avatar
DazC
Unbelievable!!!! So they got your turbo wrong again!!!
Old Jul 23, 2005 | 04:05 PM
Stu @ M Developments's Avatar
PassionFords Creator
Sadly Daz, its as bad as that MD240 on the YB.. and at similar boost, surges around the 16-18 mark. God knows what compressor it is, its the first CVH ive personally heard surge with a T3...
Old Jul 23, 2005 | 04:14 PM
DazC's Avatar
DazC
Un fucking believable!!!
Andy rang me about this wierd problem he had, like a misfire and hesitation. He came round and we both went out in it. It didn't do the surging that I noticed as we went down the bypass but I did hear a metalic rattle pinking type sound so I told him not to thrash it until you had seen the car. On the return journey it did the surge but I thought to myself that suerly it couldn't be surge cos it's just not heard of on a T3/CVH!
Old Jul 26, 2005 | 05:12 PM
AJC's Avatar
AJC
yep, its ok, im going to have big words this time, not a happy bunny
did not think it would be a big influence on the drive but it bloody is,
fookin useless at turbo force
Old Jul 26, 2005 | 09:16 PM
DazC's Avatar
DazC
I think you need some money back off them mate and get a Turbo Dynamics or a Universal Turbos hybrid!!
Old Jul 26, 2005 | 11:10 PM
GrimmeRS2K's Avatar
GrimmeRS2K
yeah i would give universal turbos a try,
Old Jul 27, 2005 | 04:59 PM
AJC's Avatar
AJC
yeah, turbo technics may be cheers chaps
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
41
Aug 21, 2015 06:47 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Bailes1992
Aug 16, 2015 07:14 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
