2WD HEADER TANK/CAP
Old Jul 10, 2005 | 01:44 PM
rabmc's Avatar
rabmc
Default 2WD HEADER TANK/CAP
Basically when im out in car and have been giving it some i look under bonnet and have water on header tank(spec r) and has sprayed around tht area now when i tighten up the cap on it it seems to tighten but cant force it up its as if once it tightens it just stops and thats as far as it goes my old rst`s caps when i tightened the felt different when they were tight , its hard to explain , but i think (dunno if they have a seal) the caps done do u think this is my problem ? or is this common its not overheating and fans come and do the usual job but when i have gave it sopm it seems to leak from somewhere and think its the cap , checked hoses and are fine , there braided so look fine ?
any help appreciated
Old Jul 11, 2005 | 07:07 AM
Alvyn's Avatar
Alvyn
cap has a rubber seal m8 get a new cap for it
Old Jul 11, 2005 | 05:15 PM
rabmc's Avatar
rabmc
Would this cause any problems if has no rubber seal mate would a normal one fit a spec r tank ? or does it have to be the same one ??
Old Jul 11, 2005 | 05:40 PM
Alvyn's Avatar
Alvyn
they have different rated pressure release valve in the caps also so has to be the correct item for the Cossie
ps if there's NO seal then yes water would get past the cap as there is loads of pressure in the system so water and steam could and would escape especially when being booted
Nov 1, 2015 06:53 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
mpilk
Sep 27, 2015 09:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
