******cosie managment******
hi,
im looking for some one who is able to build me cosie managment, in the derby area if possible,
i already have most of the componants ie
loom
ecu
efi inlet,fuel rail.
tps
idcv
throttle body
air temp
any info would be much apreciated!
loom
ecu
tps
idcv
throttle body
air temp
yes top bloke is jano!
its just a bit of a pain getting the car to london and back with half an engine,
just woundering if ther was anybody local to derby??
it seems that oddkidd creations is the only place that will do the efi/cosie managment conversion???
most places dont want to know!
so i think it looks like a long journy to jano with car trailer
at least i will know its done proper
Around Derby i would say try Dingy of off this board, he makes up soem fantastic looms, and has done a few RST conversions now. Then try and get hold of Karl @NMS, he knows his stuff and get it mapped to its full potential. Its worth a go as its alot closer then you travveling down to essex to see Jano.
All the bits you have are after I have for sale on E bay under ford escort rs turbo. I also have the bottom pulley, cam position sensor & bracket with lug wheel for pick up, crank position sensor & bracket with lug wheel for pickup ad the alternator bracket for spacing it out.
All these parts have been machined and running on my cossie managed rs turbo
