intercooler change
Old Jul 7, 2005 | 02:58 PM
doggydowg's Avatar
doggydowg
Default intercooler change
Hello guys
Have just swappd my 2wd cosworth intercooler for a forge front mount joby and evan thoe boost is the same it feels like its being strangled of power, all i can think is that my boost pipe setup is now shorter so less lag so maybe more fuel in there or something?
Has any one else had same thing ive upd my boost 1-2 psi still doesnt pull as much what could it be??? my acts are the same i would swap back but the intercooler was borrowd so i have to stick with this kit ive bought and both intercooler have same capacity too;-(
Old Jul 7, 2005 | 03:08 PM
james_birch's Avatar
james_birch
Go get it set up!
are you sure theres not an air leak!
when i fitted my front mount i fort i lost 4lb of boost cus of bigger capacity...turned out i had an airleak that made my turbo shit it's self!
Old Jul 7, 2005 | 03:15 PM
doggydowg's Avatar
doggydowg
if u have air leak mine wont run if there is any leakidge at all i will go check something dodgy cant afford a set up unemployed;-( maybe my metering head hose is loose or was loose il go check it over
thanks
Old Jul 7, 2005 | 05:59 PM
S1 JOHN's Avatar
S1 JOHN
could be the timing mate i belive sometimes this can be affected when runnin a bigger cooler
Old Jul 7, 2005 | 07:28 PM
doggydowg's Avatar
doggydowg
intercooler is same size just has bigger surface area i might have a tiny leak somewhere i cant find it thoe, il put other intercooler on 2m and see what its like and if problem goes il know its pipework allot of hassle thoe lol is there a way i can run my boost gauge so i can see what boost turbo is producing so i can compare that to what engine is running?
Is defnetly slower atcs are same so is boost something aint right;-(
Fudgey
21
Sep 30, 2015 06:19 PM
Russ Payne
Sep 25, 2015 08:29 PM
