Where do you place your Act Guage Sensor
Old Jul 5, 2005 | 06:58 PM
AKRS1's Avatar
AKRS1
Default Where do you place your Act Guage Sensor
I just recently bought a act guage but the problem is if i place the t piece connection too near the inlet manifold it gives me a false reading of around 70C which i know is wrong ive now run a long vacum tube from the inlet manifold to the back of the heater box and now only reads between 17c and 35c is this right or is there something still wrong
Old Jul 5, 2005 | 07:02 PM
Stoo's Avatar
Stoo
Ummm where did you mount the sensor?It goes into the right hand side port ontop of the inlet?
When sitting stationary it will read quite high but when on boost it should come down dramatically
You shouldnt need a vacume tube though mate,its only wires
Old Jul 5, 2005 | 07:12 PM
AKRS1's Avatar
AKRS1
i place the t piece connection in the vacum pipe that goes to the ecu. Does it matter how long that pipe is or should i place the t piece connection as close as i can to the inlet manifold. cheers
Old Jul 5, 2005 | 07:19 PM
rs_daz's Avatar
rs_daz
Ey? just screw the t bit into one of the 2 holes on the top of ya inlet manifold.
Old Jul 5, 2005 | 09:50 PM
radiant red's Avatar
radiant red
i have mine in the cross over pipe just before throttle body, i thought as close to engine as poss so you get a true reading of whats going in ya cylinders.
Old Jul 6, 2005 | 06:02 PM
Micky's Avatar
Micky
Mine is in the same place as radiant red's,just in front of the throttle body,most accurate reading will be shown from here,regards Micky
DixieTheKid
11
Jun 6, 2020 11:20 AM
Nov 1, 2015 06:53 PM
15
Oct 7, 2015 03:43 PM
rsguy
44
Sep 29, 2015 03:29 PM
