new fuel pump and still no fuel pressure at injectors!
Had no fuel pressure at injectors on my ERST was told it could be fuel pump, so fitted new one and still no change. cold start valve sprayed me in eyes though when i cracked of union on metering head? some one please help!!
there is no fuel pressure at the injectors until it is running!! if you remove the air filter and gently push the flap in the metering head down when cranking it over and the fuel should then get up to the injectors
JK12
33
Apr 26, 2021 12:09 PM
jonfoc
16
Sep 11, 2018 05:35 PM
